Old 08-23-2014, 07:28 PM   #1
cdangel0's Avatar
Television weight
We just purchased and will pick up on Thursday a 2015 Cherokee 274dbh. The dealer said if we brought a television he'd put the bracket on and hang it for us.
Ive looked and cant find anything that specifies the weight or size of the television the wall mount can handle. Just that its for LCD tv's.
I have a 32" Vizio I was hoping to repurpose to the camper.
Thoughts, ideas, opinions, or information would be greatly appreciated.
Craig & Lynn D'Angelo
Delaware
cdangel0 is offline   Reply With Quote
Old 08-23-2014, 09:24 PM   #2
Phat Phrog Stunt Crew
elind's Avatar
The flat screen TV brackets go by size. RVs usually have a backer board build into the wall. It is usually next to where the cable on the wall is located. Be careful not to put in to long screws when attaching the bracket. Usually less than 2" because the thickness of the wall.
2014 Wildcat 327ck
elind is offline   Reply With Quote
Old 08-25-2014, 12:02 AM   #3
We installed an Insignia 32" TV in our 2014 Grey Wolf. The TV weighs 10.2 lbs and we used the stock factory mount that came with the trailer. It's nice and secure on the wall but we do remove it for travel. When we were looking for a TV we wanted a 32" but had a hard time finding one where the stock mount in the trailer fit the mount bolts/holes on the back of the TV (Mount Bracket/VESA Pattern 100mm x 100mm).
marko500 is offline   Reply With Quote
television, weight
