Forest River Forums
Sunline User Photos
Old 02-13-2010, 04:43 PM   #11
Changing out tire sizes...
Originally Posted by rockwood06 View Post
Athough I have a 2006 RockWood 8314ss with a max load of 7,910 lbs, the camper came with Carlisle tires- ST 205/75R/15- load range"C" @ 50 psi. I changed them out and put on Goodyear Marathons- ST 225/75R/15- load range "D" @ 65 psi, the max weight rating on the tires is 2,640 lbs each x4. From what I can remember the Carlisle "C" range were rated at 1,840 lbs each x4.
If I read the info correctly, the "C" range tire is a 6 ply and the "D" rangs is an 8 ply. The Goodyear Marathons that I have were made in Canada.
rockwood06 (and everyone else)...
I am thinking about doing the same which is changing from ST205/75/R15 to 225/75/R15 on my Forest River Cherokee Lite 28A+. From the calculations I have done the 225/75/R15 is about .79 inches wider and about 1.99 inches taller (diameter). From "eyeballing" it, I think it will fit. Any suggestions or thoughts before I order the larger tires.
Oh, my main reason is I want a 10 ply tire vs a 6 ply.
-Chris
Chris Gaskins
Austin, Texas
http://thegaskins.dyndns.org
2007 Forest River Cherokee Lite 28A+
2008 Ford F150 Lariat SuperCrew 4x2
5.4L / Auto Trans (Stock)
EAZ-Lift Weight Distribution Hitch and Sway Bar
cgaskins is offline   Reply With Quote
Old 07-14-2010, 10:25 PM   #12
Unhappy Response to old message but meets my whining needs
Just had a major blow out on my trailer on my way home from Vacation. Had one a few months ago. Decided to do some research since I bought two new Carlisles t. I dug out all the paper work that came with trailer. Yes my trailer which I bought new is five years old..... What irritates me is the paperwork on the trailers tires are Carlisle but what have actually been on the trailer from the time I got it are Nanco. What is up with that? Did Forest River shaft me or did the dealer? This has been a learning experience on tires.
I am going for the gusto with load range E. If Carlisles are junk then at least I am going to have load range E to help compensate. I know there are G but that might be real overkill.
Thanks for listening http://www.forestriverforums.com/for...ies/crying.gif
tahoekid is offline   Reply With Quote
Old 07-14-2010, 10:47 PM   #13
Let me chime in too, just took a Carlisle Radial Trail off my 09 Flagstaff 26 rbss purchased 13 months ago. Sidewall badly weather checked, kept pressures up and only had about 400 miles on it! Other 4 are out of the same batch so we'll see how they fare on 130 mile trip end of the month!
09 Flagstaff 26RBSS
08 Silverado 1500 Crew
dlc49 is offline   Reply With Quote
Old 09-06-2010, 01:55 PM   #14
Have a 2001 27.5 ft. and had 2 blowouts that had Carlisle ST205/75/R15 on it in the last few years. Each blowout caused about $1K in damage. More I looked into it, I was not comfortable with the max loading for the tire and the dry weight of the camper. With it loaded it was right near the max for the tires. I went ahead and replaced all 4 with ST225/75/R15 tires. Now this caused me to do a little modification to the Fender molding to gain clearance (took a cutoff grinder and took the lip off for 2 to 3 inches on the front leading part of the molding). Have much better saftey margin on the tires now, which should translate to running a little cooler also. One note when changeing out the old tires found that the steel rims had actually bent a little from the force of backing into sites (every watch the twist in the axels and tires as you back up, will make you cringe) . You may need to take that into consideration when buying tires also, that you may need a rim or two.
Ole Grizz is offline   Reply With Quote
cherokee
» Online Users: 549
107 members and 442 guests
0721SSROO, 1stvcross, 4bnabird, 4Jeeperz, 4runner freak, acadianbob, Adony, Barnman1, BigKidzFun, bignugget, bikendan, bka4tcu, BlakeB, BOBFIDY, bowtang2001, brookside, Browndog, bumper, Cafjackracing, caper, cdbus, cgreen1509, cgsparks1, chof16, cllecr, comfun1, Cowracer, cyclepuck, danred, darkcloud, daw592, ddurnell, deerslayer, Dennis and Julie, dezeldad, donn, drb1256, Drmstx62, dunnnc, EastlakeRoo, extremebike, flc, Flying dutchman, fordmantpw, FreedomTracker, frfan, GeorgieGirl, gerrym51, gimp425, grhodes50, herk7769, hjgrimm1, Hob, hoovercab, Indy Steve, Itsthetwoofus, Jeep4Two, JMF, JoeR, Joseph5410, jtstromsburg, keep camping, kegoneill, kgmat, kootenayrig, Kricket, KRS, Laura, lemoj1, LFugate, Lonewolfcry, lowbubba, mayorvic, mcbride5, melbornj, Mickey1, MREZ, NeilM108, newby, nuisance, pg_rider, popeye59, RalphieG, redfox217, Redheaded blue tick, Reneedann, rkswyo, Rugged Brown, Sailfish Bret, Skabi, skipper194242, softwarejoe, Tee, tessval, THELMALOUIE, Titleguy, tking01_2000, torben, travyp, treadwelll, TTNewbees, vp22er, VTX Al, wayne anthony, Wiscampsin, wolfpack21643, yvesm
Most users ever online was 996, 05-22-2012 at 11:04 AM.
Close [X]
