Old 08-16-2019, 07:43 PM   #1
mikdanmck's Avatar
Tires.........again
I got bit by my Castle Rocks. Date code 5016. Less than 7500 miles.
Heard slight pop crossing bridge didnít think much about it. About 2 miles later more noise from behind. Looked in mirror and saw tire smoking. TPMS never alarmed. 66psi and 101 degrees. When I pulled over.
Time for new onesClick image for larger version
ID:	212615Click image for larger version
ID:	212616Click image for larger version
ID:	212617Click image for larger version
2018 Flagstaff 831CLBSS
2017 F250 Super Duty 4WD 6.2 3.73
mikdanmck is offline   Reply With Quote
Old 08-16-2019, 07:49 PM   #2
That sidewall sure looks like you dropped it into a pothole pretty hard. Both inside and outside have the same marks. I would not call that the tires fault.
MtBiker is offline   Reply With Quote
Old 08-16-2019, 08:07 PM   #3
Looks to me like it sat flat in the mud after failure.
Days Camped: '16=46 '17=30 '18=51 '19=50
Old 09-06-2019, 09:35 AM   #4
Wrench Turnin Fool
Arctic Wolf's Avatar
66psi? Shouldn't it have been 80?
Not all who wander are lost...
But I usually am
2001 Coleman SantaFe pop up
Excited new owner of 2018 Arctic Wolf 315TBH8
Towing with a 2005 F-250 5.4 GASSER
Arctic Wolf is offline   Reply With Quote
Old 09-06-2019, 09:57 AM   #5
john5646's Avatar
Take the castle rock tires out of use. This one was a spare, never on road... blew through cover. Itís not a debate when they only last two years and blow. Click image for larger version
ID:	214322Click image for larger version
john5646 is offline   Reply With Quote
Old 09-06-2019, 10:19 AM   #6
Originally Posted by john5646 View Post
Take the castle rock tires out of use. This one was a spare, never on road... blew through cover. It’s not a debate when they only last two years and blow. Attachment 214322Attachment 214323
WOW! and Ouch!
That is the 2nd one I've read about that blew and never was in use.
Old 09-06-2019, 10:42 AM   #7
WOW! and Ouch!
Wondering what the black cover does to the tire pressure in the sun. Additional note, the compounds in tires
engineered to keep the tires pliable require the tires be rolling with a proper load on them. My rig is stored with the sun on the front. Follow this forum long enough and you'll hear almost everything can fail...
myxkp is online now   Reply With Quote
Old 09-06-2019, 11:44 AM   #8
Fulltime family RVer
What TPMS brand/model?
Old 09-06-2019, 12:01 PM   #9
Iwannacamp's Avatar
As a disclaimer.... I have NO loyalty to CR
There is something going on with that tire..... The sidewall markings are ending/starting exactly where the rupture/failure was.
From the pictures I see it was an impact related failure. The Inside pics of the tire would be interesting to see... I am betting on some "pinch" marks inside the tire.
Maybe WM or Tireman will be along to help
2017 Puma 297RLSS
tire, tires
