Old 05-17-2012, 10:58 AM   #11
BlakeB's Avatar
Originally Posted by BigTJohn View Post
My Touch works as stated BUT - only has stereo at the outside station and the A and B switches are for the MONO speakers inside. "A" switch turns the front speaker on/off (near the entertainment system, and "B" will turn om/off the speaker in the rear living area. Why is stereo not available (other than there are ONLY those two speakers). I also hve not been able to get the VIDEO feed (not the antenna feed, which does function) to get a video signal to the outside station (audio does work from a DVD, just no video). Anybody have any ideas on any of the above mentioned problems?
BigJohn... I havent tried mine outdoors but if you think about it.. you only have one coax (cable), and 1 RCA.. That RCA is only going to be able to do either audio or video. Not both. It will all depend on what it is plugged into behind the radio. My guess would be it is audio but I dont know. Like I said I havent tried mine.
If It is hooked up as audio, those speakers outside would have to be in parallel off of only one channel (actually half of a ch..right or left). I'll have to try it this weekend and post an update.
I may just rewire mine all together and put audio/video and true stereo..outside
TT = 2014 Palomino Solaire Eclipse 318TSBHK
TV = 2014 Ram 2500 Big Horn 6.4L V8
Pit Crew: DW (Robin)
Kids: 3yo DD (Riley), another DD cookin (Kennedy)
Security: 5yo Boxer (Sasha), 14yo yorkie (Porter)...he was married in
BlakeB is offline   Reply With Quote
Old 05-25-2012, 09:30 AM   #12
Lonewolfcry's Avatar
It is supposed to be wired (RCA is video from DVD and coax is antenna signal) this means audio from DVD would come from DVD player to outside speakers and audio from antenna through tv speakers.
Lonewolfcry is offline   Reply With Quote
Old 05-26-2012, 02:09 AM   #13
Rsgtivr6's Avatar
I didn't even get to try the Touch Audio unit, it was swapped with a Jensen before our PDI since I made it clear I knew it was a "troubled" brand. Mine was the 5th one she changed that week...
TV: '17 Ram 2500 Big Horn CCSB CTD 4x4
TT: '18 Wolf Pack Limited 325Pack13
Tow Acc: Andersen Ultimate Hitch 2 goose ball mount, AirLift 5000 bags and HD compressor system
Rsgtivr6 is offline   Reply With Quote
Old 05-27-2012, 10:45 PM   #14
I have the Jensen also. My touch audio lasted about one month. If you have a outdoor ent hookup I hope the dealer put a splitter on the video output. The Jensen only has one output. Other then that it's been a great unit.
Old 05-28-2012, 03:13 PM   #15
BigTJohn's Avatar
BlakeB and Lonewolfcry - I DO get stereo sound from the Touch DVD but NO video signal to the RCA at the outside station. Coax works fine from the antenna and tv works fine outside. Just wish the RCA video feed worked as it should. Still have not removed the Touch to see what/why neither inside is stereo (only one speaker for A and B switch). I need to find out if I can get wires run through the ceiling for another speaker at each position (one front, one rear). I just do not think there is an easy way to get a "fish" to get the wire(s) run. Maybe if I use on of the other wire runs from the other speaker I can pull it back to origin then pull it back with cord attached to the speaker end (done before I pull it back to source). Hope this makes sense in the narrative.
BigTJohn is offline   Reply With Quote
Old 06-26-2012, 06:54 AM   #16
BigTJohn's Avatar
Fixed the video problem-loose connector on back of Touch. Stereo sound still a problem inside.
Brenda and John
Master Blaster of the Navy
28bh
