Old 08-27-2018, 07:42 AM   #1
Towing Arctic Wolf 285 with short bed?
I have a 285 and have an F250 short bed on order so my question for anyone with this combination is: do you use the wedge and rotate at the trailer or do you let it pivot at the hitch?
Artspe is offline   Reply With Quote
Old 08-27-2018, 07:49 AM   #2
Mr Towed's Avatar
I honestly have no idea what you mean by "the wedge". I'm interested to see what this is all about, though.
Travel Trailer: 2004 Flagstaff 25LB
New Tow Vehicle: 2017 F-150 3.5 Ecoboost, supercrew short bed FX4 Lariat
Old Tow Vehicle: 2009 Silverado 2500HD 4x4 Ext. Cab Short Bed
Travel Pooch:Sophie the Sato - Cats: Rhody and Hazy
2018:22nights / 2019:31Nights / 2020:18Nights
Mr Towed is offline   Reply With Quote
Old 08-27-2018, 10:41 AM   #3
NMWildcat's Avatar
If it was me, I would get a wedge for your specific hitch and USE it! The universal may work, but hitch specific ones seem to work better with your Revolution.
We have had two sidewinders and love them. No worries about any tight turns. One less thing to worry about.
Scott and Liz - Southern NM
2007 Chevy 2500HD Duramax
NMWildcat is online now   Reply With Quote
Old 08-27-2018, 11:10 AM   #4
Canadian Member
It looks like the OP's Arctic Wolf 285 has the Reese Revolution pinbox that moves the pivot point back about 22". Its the OEM version of the Reese Sidewinder.
Revolution
Sidewinder
https://www.etrailer.com/Fifth-Wheel...e/RP61420.html
If the factory put one on, I'd definitely use it with a wedge custom made for the 5th wheel hitch in the bed of your truck.
Old 08-27-2018, 12:57 PM   #5
Grapehound's Avatar
We pull a Rockwood 5-er with a short-bed RAM dually and we use the wedge so we wouldn't take out our rear window on tight turns. We did buy a custom wedge though made specifically for our B&W Patriot hitch and replace the generic wedge that came with our Rockwood. Rockwood has to provide a generic wedge since there are many brands of fifth wheel hitch.
Mr. Towed: The wedge mounts around the trailer hitch pin to prevent the trailer hitch from pivoting on top of the hitch (as normal fifth wheels do). Instead, one removes two bolts from the back of the Sidewinder or revolution hitch so that by locking the front kingpin in place, the hitch pivots about 22" further back from hitch pin. This makes sure the nose of the trailer is pushed back about 22" further from the cab on tight turns and prevents it from pivoting into the cab. Here's a Reese Sidewinder ad to explain.
2014 Rockwood Signature 8282 Ultra-Lite
2008 RAM 3500 HD DRW Laramie Megacab
6.7 Cummins Turbo Diesel
Grapehound is offline   Reply With Quote
Old 08-28-2018, 09:40 PM   #6
Mr Towed's Avatar
Thanks, originally I didn't realize this was pertaining to a 5th wheel so it makes more sense now. Pretty interesting stuff. I guess it's easier and less maintenance than one of those sliding fifth wheel hitches?
Old 08-29-2018, 04:11 AM   #7
Grapehound's Avatar
"Thanks, originally I didn't realize this was pertaining to a 5th wheel so it makes more sense now. Pretty interesting stuff. I guess it's easier and less maintenance than one of those sliding fifth wheel hitches?"
Certainly easier and cheaper than buying a sliding hitch, though the sliding hitches are very nice. My Rockwood fifth wheel came with a generic wedge, so it actually costs you nothing to switch to the rear pivot point on the Sidewinder hitch. Just bolt the wedge to your trailer to lock or freeze the front pivot on the king pin and remove two bolts from the rear of the hitch so it pivots there. Easy peasy.
bed, towing
