Originally Posted by BigPatCal
The one thing that I don't like is if you mount it on the back of that wall (int the bedroom) you cant slide the doors open all the way without bashing the TV.
I just asked the same thing in another thread about not being able to slide the doors all the way open with a TV mount on the wall. If you need a TV in the master, it is intended to be hung from the ceiling using a ceiling mount like this-
http://www.amazon.com/VideoSecu-Ceil.../dp/B000V8VW6W
Unlike the interior walls, you can actually find a stud in the form of a rafter to mount to in the ceiling but be careful, they use 2"x2" in the construction of these things which won't take much for a lag bolt to split. I would use screws with the intention of never traveling with the TV mounted. YMMV.
Originally Posted by Holmes42
So would a 32" work? Mounting on the wall? Or putting it on the mantle? How do you secure it on the mantle?
Yes, 32" would work. Compared to our 37", I don't think you could go much bigger than a 40" perhaps a 42" TV therefore, you should be good with anything smaller. You won't be able to use the supplied plastic wall mount which is for smaller TV's... the supplied mount is actually for computer monitors and I suspect smaller TV's. Either way, you would not want to travel with it hanging on the way or sitting on the mantel. We simply lay our TV face down on the master bed when we travel.
