Old 10-11-2014, 11:39 AM   #1
Jwatty's Avatar
TV wall mounts inside and out.
Our cable/power outlets are on the back of the TV, so, I can't get the TV to slide into the built in mounts. Suggestions?? BTW...I searched for this topic before posting.
TIA!
Jwatty is offline   Reply With Quote
Old 10-11-2014, 05:19 PM   #2
Lloydg's Avatar
Send a message via AIM to Lloydg Send a message via MSN to Lloydg Send a message via Yahoo to Lloydg
Are you trying to slide the TV off the mount or slide it onto the mount?
Heartland Big Country 3150RL
2013 Ford SD F250 4x4 SC; 6.2
Reese 18K Elite w/slider - Ada, Michigan
Lloydg is online now   Reply With Quote
Old 10-11-2014, 06:27 PM   #3
Jwatty's Avatar
Trying to slide it into the mount.
Old 10-12-2014, 07:43 AM   #4
Lloydg's Avatar
I don't know how to help you. Maybe pictures of the mount on the trailer and on the TV would help. Is it just a matter of fishing around until the mounts line up?
Old 10-13-2014, 09:37 AM   #5
Jwatty's Avatar
Name:	ImageUploadedByForest River Forums1413210889.772979.jpg
ID:	64655Click image for larger version
Name:	ImageUploadedByForest River Forums1413210935.674029.jpg
The cords are on the back of the TV, so, they are stopping the TV from sliding into the mount.Click image for larger version
Name:	ImageUploadedByForest River Forums1413210992.127310.jpg
Old 10-13-2014, 09:46 AM   #6
offroad's Avatar
With that mount you'll probably need 90deg angle connections, you can get one for the coax at WM or RS. There are also 90deg power cords.
2017 Open Range - Light 297RLS, BX1 Gooseneck
2014 Ram 2500 4x4 CCSB 6.7L 68RFE
offroad is offline   Reply With Quote
Old 10-13-2014, 09:48 AM   #7
Jwatty's Avatar
Awesome! Thanks so much!
Old 10-13-2014, 09:50 AM   #8
Lloydg's Avatar
I see you're trying to mount the tv to the outside mount and there is limited space between the wall of the trailer and the backside of the tv. I might think about adding some spacers between the tv and the mount so that you can get the clearance you need. I say the tv and not the wall of the trailer so you won't have to worry about compromising the seal. Try you local hardware for some 1/2 inch spacers and don't forget you'll probably need some longer screws too. Good luck.
Old 10-13-2014, 09:51 AM   #9
Lloydg's Avatar
That's a good idea too.
Old 10-13-2014, 09:51 AM   #10
Looks like you could put some washers or spacers between the TV mount and the TV. Make sure the screws don't go through the led panel though. I intend to get this same mount for the bedroom wall and the outdoor wall. One less TV to carry. My TV connections are on the side of the unit fortunately.
2013 Ford f-150
2015 Rockwood 2703WS
Rockwoodjoe is offline   Reply With Quote
mount
