Old 06-26-2012, 04:31 PM   #21
BigTJohn's Avatar
You will have to pull a video/coax cable from the entertainment center to the outside are and install a tv mount. Once those are done you should be good. I do not know the exact layout/interior plan and how cables are currently run so you will have to work out best way to run them.
Brenda and John
Master Blaster of the Navy
BigTJohn is offline   Reply With Quote
Old 06-26-2012, 04:53 PM   #22
croball's Avatar
Ok thanks for your help.
croball is offline   Reply With Quote
Old 06-26-2012, 04:58 PM   #23
Herk7769's Avatar
My solution to boondock TV watching outside.
I plan on running a composite or HDMI cable out there as well (Next time the belly covering has to come down.)
Name:	Wall Outlets Entertainment Center 4.jpg
HAM CALLSIGN - KC3FFW
Old 06-26-2012, 06:14 PM   #24
GASPEDDLER's Avatar
I installed a directv receiver and DVD player on top of my fridge in my outside kitchen. When I'm outside I run an HDMI cable out of the kitchen opening ,under the stairs and up to my flat screen which is mounted to the left of the door. When I go to bed I merely roll up the HDMI and tuck it in next to my fridge and close up my outside kitchen.
2012 F-350 4x4 King Ranch Super Duty CC 6.7 Turbo Diesel 3.55 e-locker
2011 Palomino Puma 30KFBDS with Side Paw Kitchen and Bunkhouse
Equalizer E2 Hitch
GASPEDDLER is offline   Reply With Quote
Old 06-26-2012, 06:55 PM   #25
Herk7769's Avatar
Cheapest and longest cables I have found.
Cyberguys.com - hdmi cables has returned the following search results
If you are running output to a large screen monitor with a DVI input:
http://www.cyberguys.com/product-sea...ue=16ft.+(4.9m)
Old 06-26-2012, 10:25 PM   #26
Rsgtivr6's Avatar
Cyberguys.com - hdmi cables has returned the following search results)
Bah, if you want cheap cables, Newegg.com is where you go. They have HDMI's from 3-100ft. Just remember, after 50ft you might get a lot of signal degradation.
HDMI Cables - Newegg.com
TV: '17 Ram 2500 Big Horn CCSB CTD 4x4
TT: '18 Wolf Pack Limited 325Pack13
Tow Acc: Andersen Ultimate Hitch 2 goose ball mount, AirLift 5000 bags and HD compressor system
Rsgtivr6 is offline   Reply With Quote
Old 06-27-2012, 08:32 AM   #27
Herk7769's Avatar
Wow, Thanks. You are right.
They beat Cyberguys like a drum!
Old 06-27-2012, 10:34 PM   #28
I but from Cable Wholesale. I install these all the time and have never had a bad cable. Get a Class 2 cable. They are designed for in-wall installations (thicker for vibrations/rubbing) and have better shielding. Remember, you get what you pay for.
Top B is offline   Reply With Quote
led pad
