Old 04-14-2016, 07:27 AM   #11
KyDan's Avatar
Some good advice here but it is brand/model specific.
My Atwood water heater has an aluminum tank with a plastic drain plug and NO anode.
I almost never drain my WH and over the last 11 years and 4 different trailers
we only found the water in the WH tank had gone sour 1 time.
YMMV.
Happy Trails!
Peace!
Dan & Rita D
Blue Ox WD hitch
Old 04-14-2016, 07:35 AM   #12
Oakman's Avatar
I have never bothered to drain the hot water tank except at the end of the season when we winterize. I've never had a problem with smelly water but perhaps that has something to do with where the water came from on your last trip.
We're going into our 13th season with a fifth wheel. It's a non-issue for us.
Bob and Joyce
2013 CC Silverback 29RL
2010 Ford F250 XL Crew Cab 6.4 liter diesel
ATU Local 788
Oakman is offline   Reply With Quote
Old 04-14-2016, 08:29 AM   #13
Tyler_13's Avatar
Water heater.
Thanks everyone. Sounds like once again there isn't a right or wrong way. Just do what works for us. We camp at the lakes around us and can't camp every weekend. Because of that I will most likely empty it after every trip. It doesn't take that long and we don't even drink the water in the trailer when we are there. Buy bottled water for the weekend trips.
Tyler_13 is offline   Reply With Quote
Old 04-14-2016, 08:51 AM   #14
I drain after every trip just because I don't always know if I will be camping in the next week or two. I just don't want the water to smell when I go to take a shower.
My household water heater is a tankless electric so I never have to worry about draining it
2016 Vengeance 320A
2015 Chevy 2500HD LT 6.6L 4x4 ccsb Z71 trim
2012 HD Electra Glide
Andersen Ultimate Aluminum fifth wheel hitch V2
Days camped '16=43, '17=47, '18=2
Electra glide is offline   Reply With Quote
Old 04-14-2016, 09:39 AM   #15
younggeezer's Avatar
Do you guys put thread tape on the anode?
younggeezer is offline   Reply With Quote
Old 04-14-2016, 10:00 AM   #16
Flybob's Avatar
I replaced my plastic drain plug in my Atwood WH with an adapter to allow it to connect to a short piece of 1/2" high temp hose and a 1/4 turn valve. Draining the WH is a simple as opening the outside door and turning the valve. The hose is just long enough to keep the water from running down the side of the TT but short enough to sit nicely on the bottom of the WH frame. Yes I always drain WH and water lines. If you are curious as to what happens, just fill a glass about half way with water from the WH. Cover it and let it sit on the counter of your RV until your next trip. Then decide if it is OK for you to use.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
Old 04-14-2016, 10:28 AM   #17
YES!!!
2011 Traverse LT, 3.6L, FWD
Old 04-14-2016, 10:47 AM   #18
We open low point drains every time we break camp. (Which drains water heater) It saves us from dragging extra 50 lbs. Will I save gas, yes. Will I notice I'm saving gas? No, but my tires appreciate the gesture.
2016 Ford F250 XLT 4X4 6.2L
Hensley Arrow
Nights camping in 2017: 20 nights
Miles traveled in 2017: 1,530
uhduh camping is offline   Reply With Quote
Old 04-14-2016, 11:17 AM   #19
Canadian Member
itat's Avatar
I prefer to just pull the plug on my Suburban WH. That ensures that no particles in the tank get into the water lines and makes it easier to remove the anode rod the next time. Plus it drains much faster. I would open the low point drains too just to get all the water out of the system so it doesn't sit in there a get stale.
2011 Rockwood Signature Ultra Lite 8293SS, 12K Equal-i-zer WDH
2009 Ford F-150 XLT SuperCrew, 5.4L, 5'6" bed (2012 - 2016)
Old 04-14-2016, 11:21 AM   #20
Originally Posted by jeff64 View Post
X2 and they are magnesium according to the literature. Don't forget the reducer bushing if you are putting it in a Suburban WH
The issues with using this type of "A-Rod drain valve" in a Suburban Heater is you have just Moved your Drain Hole UP,the 3/4 to 1/2 bushing plus the Small Hole size in the Little drain valve! This allows Crud to build up on the Bottom of the Heater that would Normally drain out the Factory 3/4" TPT Hole! Youroo!! Also draining your HWT from your LP Drains lets the Crud from the Tank go Downstream in you Pex lines!
heater, water, water heater
