Old 04-12-2016, 06:17 PM   #1
Tyler_13's Avatar
Water heater.
I was just wondering if it is good to drain the water heater after every trip? Also should you open up the kitchen faucet so the water can drain back or will that just cause a bunch of air to get in the lines?
Tyler_13 is offline   Reply With Quote
Old 04-12-2016, 06:32 PM   #2
Canadian Member
itat's Avatar
If I won't be using mine for more than 2 weeks I drain it. I don't want stale water in the WH with the potential for something to start growing!
It doesn't hurt to open the hot water faucet to drain the WH. The air will come out the next time you start running the water.
2011 Rockwood Signature Ultra Lite 8293SS, 12K Equal-i-zer WDH
2009 Ford F-150 XLT SuperCrew, 5.4L, 5'6" bed (2012 - 2016)
Old 04-12-2016, 06:32 PM   #3
Rad
Rad's Avatar
Yes, yes, yes! Otherwise you get smelly hot water!
Sent from my iPad using Tapatalk HD
Rad is offline   Reply With Quote
Old 04-13-2016, 10:02 PM   #4
younggeezer's Avatar
Do you pull the plug/anode to drain the heater?
younggeezer is offline   Reply With Quote
Old 04-13-2016, 11:05 PM   #5
WFD
Yes but make double sure your switch to the hot water heater is off, otherwise you will burn it out in just a few seconds...your water heater is not that much different than your house hot water tank...do you drain it whenever you go on vacation and won't be around for a week or two???
2016 Chevy Silverado 2500 Duramax
2016 Rockwood 8289WS, Diamond Pkg.
WFD is offline   Reply With Quote
Old 04-13-2016, 11:38 PM   #6
Just a member
kandl's Avatar
X2 - takes but a few minutes.
Keith, Lori & the Wild Bunch
TT: 2011 Rockwood 8293RKSS
TV: 2009 Dodge Ram 1500 CC 4x4 (ya.. it's got a Hemi
kandl is offline   Reply With Quote
Old 04-14-2016, 12:13 AM   #7
I've never drained mine, and I've never had smelly water. Maybe I've been lucking, I don't know.
2011 Traverse LT, 3.6L, FWD
Old 04-14-2016, 06:36 AM   #8
TURBS's Avatar
No, but my household water heater also stays on 24/7 365 .
Also my household water heater ALWAYS has the same supply water.
I drain my water heater if going to be longer then 2 weeks.
Relive any water pressure, open pressure relief valve and remove plug.
Old 04-14-2016, 06:55 AM   #9
spydernut's Avatar
When you remove the anode rod from your water heater to drain it, replace it with a universal anode rod with drain valve. It makes draining quick and easy. Camping World stocks them.
spydernut is offline   Reply With Quote
Old 04-14-2016, 07:14 AM   #10
jeff64's Avatar
X2 and they are magnesium according to the literature. Don't forget the reducer bushing if you are putting it in a Suburban WH
2016 Flagstaff 27VRL Emerald
14K Equalizer
2014 GMC 2500HD CC 4X4 6.0L
heater, water, water heater
