Old 05-14-2016, 05:23 PM   #1
kark0202's Avatar
Water heater question
Does my water heater only draw out of the fresh water tank? I am new to this but when tank was empty and we were only hooked to garden hose we didnt have any hot water.
kark0202 is offline   Reply With Quote
Old 05-14-2016, 05:30 PM   #2
You should have (2) City water and FW Tank! Youroo!!
Old 05-14-2016, 05:31 PM   #3
Flybob's Avatar
The water heater inlet is connected to the cold water line in the RV. If you are using the FW tank and water pump, that line is being fed by the water tank. If you are connected to city water the cold water line is being fed by city water. The city water connection and the fresh water tank fill are separate on most TT. Some larger units have one connection and an internal valve to decide where the water goes. Be sure to fill the WH before turning it on.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
Old 05-14-2016, 05:42 PM   #4
Ford Idaho's Avatar
Not your unit but it may be similar.
I must switch the valves depending on what I want to do/use.
Old 05-14-2016, 05:43 PM   #5
kark0202's Avatar
I believe the wh fills itself
Old 05-14-2016, 05:44 PM   #6
kark0202's Avatar
Name:	ImageUploadedByForest River Forums1463265845.622522.jpg
2013 grey wolf 27bh
Old 05-14-2016, 06:11 PM   #7
Oaklevel's Avatar
Sorry more questions .........
Have you used the trailer this year (dewinterized) ?
How were you trying to heat the water propane or electric..........
If electric and tank empty you may have burnt the element.
Sorry for basic questions are you plugged into shore power??
2005 Dodge 3500 Cummins
2017 Wildwood Lodge 4092 BFL
1966 Mustang GT
1986 Mustang SVO
Old 05-14-2016, 06:16 PM   #8
Ford Idaho's Avatar
It does require some human intervention.
Valves must be switched or the connection it's self in some cases.
WH pressure relief valve must be opened to vent all the air to avoid burning up the element.
Old 05-14-2016, 08:06 PM   #9
kark0202's Avatar
Propane
Already dewinterized
Shore power yes.
Old 05-14-2016, 08:26 PM   #10
deartruc's Avatar
When you dewinterized fif you turn the water heater bypass valves back? Not to contradict Ford, but the owners manual and when I troubleshot a leaking relief valve in my previous htt, said to not bleed the air out. There isn't any expansion tank, so the airgap in the top of the tank is used for expansion.
2017 GMC Yukon
2015 Roo 23 ikss
deartruc is offline   Reply With Quote
Old 05-23-2016, 08:33 AM   #11
Twistedpairs's Avatar
I have a 2015, there are two bypass valves you access under the queen bed (the handles are elongated and the water flows the length of the handle) there is also a switch on the water heater that you access from the outside access panel. If you are on shore power, it will run off electric automatically. If you still don't have hot water check the circuit breaker on the master panel or worst case scenario, the element is burned out and needs to be replaced.
'15 26DBH pushing our '18 Ram 3500
Twistedpairs is offline   Reply With Quote
heater, water, water heater
