Ok, this might sound like a stupid question, but where is the pump located on a Cherokee Lite 28A+? I was going to winterize today and I can't find it. I can hear it pumping but I can find the access panel for it.
i had a coachman of a similar floorplan, it was under a panel in the clothes closet. I liked ot never have found it, or the screws to open the access, they were really countersunk
good luck
Living in the Piney Woods of Texas.
I asked this same question! My 29b+ is under the bathroom sink. There are 2 screws in an access panel you undo and there it is. Also you will need a 1 1\16 socket to drain your water heater if it is like mine. Make sure the water is not hot. It did squirt alot when I removed it.
Steve
Steve, Thank you. I suspected that was where it was based on the sounds I was I hearing.
