Old 06-26-2018, 07:28 PM   #1
Water pump not priming
I have a 2018 grey wolf 27dbs. Just today the water pump wonít stop, and when it does an I turn on water pump wonít keep up. Then the pump cycles every 3-4 minutes. The fresh water tank full. No leaks underneath. And checked all the water taps
Darrinlambier is offline   Reply With Quote
Old 06-26-2018, 07:50 PM   #2
Mr. Dan's Avatar
Maybe someone accidentally bumped the antifreeze/winterizing valve and your pump is sucking a little air through it.
SEARCH is your friend!
Nights Camped: '13 = 49/'14 = 74/'15 = 74/'16 = 85/'17 = 110/'18 =111/'19 = 86; booked = 0
Old 06-26-2018, 07:52 PM   #3
I just checked an all looks good there
Old 06-26-2018, 07:52 PM   #4
SeaDog's Avatar
Also check the the suction strainer cap is on tight
Retired Navy
Jake my sidekick (yellow Lab)
2016 Flagstaff 26 FKWS
Old 06-26-2018, 07:54 PM   #5
2018 Dynaquest 38TS
is your outside shower off?
DR Quest is offline   Reply With Quote
Old 06-26-2018, 07:54 PM   #6
I tightened it a lil an itís tight, I moved it a lil but still nothing
Old 06-26-2018, 07:55 PM   #7
Yes both out door showers
Old 06-26-2018, 08:56 PM   #8
Is your water heater full? Filling it can take a long time and take away pressure.
We had a similar problem with our 27dbs in that after 6 months, all the sudden, the pump would not stop. Still got ok pressure, but pump would not shut off. Water tanks full, no air suction, hot water tank full.
When it would keep running, I would tap on the pressure switch on the pump with pliers and it would shut off. It started with an occasional run-on, then got to where it would run-on all the time. The pressure switch was bad. Brand is Artix PDS3B-130-1260E. Never heard of that brand so I just ordered a sureflo pump and replaced it.
chickenwing is offline   Reply With Quote
Old 06-26-2018, 08:59 PM   #9
I talked to dealer gonna take it in. This weekend is Canada day an we have city hook up. Then a few weeks off til our holiday so he can fart with it haha thanks for the help. The dealer is hour an a half away which is a bummer, but a great restaurant around the corner, so it all works out haha
Old 06-26-2018, 09:02 PM   #10
Sounds like a plan. Oh, one quick thing you could check if you wanted is the filter screen to make sure it is not clogged. The filter is connected to the inlet side of the pump.
Old 06-26-2018, 09:03 PM   #11
I checked it itís clear. I was hoping something simple. He thinks itís the pump or parts in the pump
Old 07-19-2018, 07:49 PM   #12
Pump
We have the same issue ...3rd trip out and the Artix pump continued to run then stopped completely... Unfortunate issue with a new camper ...sounds like a bad batch of pumps...
mcmfw2 is offline   Reply With Quote
Old 07-19-2018, 08:38 PM   #13
I talked to my dealer an when I got mine to his place to look at. It started working fine...go figure. He said it wasnít uncommon for some debris to make the pump not prime, especially on a new trailer
pump, water, water pump
