Old 11-09-2018, 02:46 PM   #1
Water Pump positioning
So in looking under the queen bed in my 2019 Wolf Pup 16BHS I see the water heater and the water pump. A few things caught my eye.
1. There appears to be a kink in the hose attached to the water pump, shown below:
Can I just unscrew the water pump from the floor, re-position it to relieve the kink and re-attach the pump to the floor in the new position? If so, should anything be done to fill the old holes?
2. There appears to be an electrical junction of sorts laying next to the hot water heater:
Should this be secured somewhere?
Thanks for the help.
Eric
20vmki is offline   Reply With Quote
Old 11-09-2018, 02:58 PM   #2
2016Pup's Avatar
Wow, looks like they kinda rushed through that area during the build process. I would definitely do both things that you stated. You could just pivot the pump on one of the screws so you only need to make one new hole. I am not sure the screws go all the way through the floor so you may not have to put anything in the old hole but you can put a spare screw back in the hole easy enough....
2016Pup is offline   Reply With Quote
Old 11-09-2018, 03:05 PM   #3
Mr. Dan's Avatar
1. The water pump can be moved. They usually have 4 screws so pivoting the pump would require 3 new holes -- but no problem. Use the same screws you removed and (I'm sure) they won't be too long to reinsert in a different place. I would not worry about the old holes but it wouldn't hurt to squirt a little caulk in each one.
2. The water heater's control board is normally stuck to the side/top of the heater using the double-sided tape shown on its left surface.
SEARCH is your friend!
Nights Camped: '13 = 49/'14 = 74/'15 = 74/'16 = 85/'17 = 110/'18 =111/'19 = 86; booked = 0
Old 11-09-2018, 03:09 PM   #4
Both things very common in the R/V industry and reported here many times.
Yes, simply reposition the pump to relieve the kink and use something better than the useless double sided tape the factory uses to attach the water heater control module to something close by. There have been reports of them lying on the floor and a water leak developed and ... well... you know what happens next.
In addition, make sure the kinked hose opens fully once repositioned. Sometimes that type of hose takes on a bit of a 'memory' and holds the kink even once repositioned. I've had a couple hoses I had to actually cut the kink out to eliminate it.
Days Camped: '16=46 '17=30 '18=51 '19=50
Old 11-09-2018, 03:21 PM   #5
nomad297's Avatar
Sometimes you can just put a hose clamp over those stubborn kinks and tighten it down to keep the hose round.
Bruce
Old 11-09-2018, 03:35 PM   #6
Bruce
Yes, correct.
I've also used several zip ties wrapped tightly next to each other to accomplish the same.
Old 11-09-2018, 03:43 PM   #7
Looks like a 4:55 pm Friday build. I'd loosen the pump and reposition.
TheWolfPaq82 is online now   Reply With Quote
Old 11-20-2018, 03:19 AM   #8
Just to follow up, I moved my water pump and got rid of that pesky kink!
Old 11-20-2018, 03:34 AM   #9
onetonford's Avatar
My water heater controls are ty-rapped to the top of the water heater tank.
2001 Ford F-350 DRW 7.3
2011 25 RL Wildcat
former fiver 1976 Fourwinds had for 35 years
onetonford is offline   Reply With Quote
Old 11-20-2018, 03:53 AM   #10
Mr. Dan's Avatar
Attachment 191844
Good job.......... and thanks for reporting back!
pump, water, water pump
