Old 07-31-2016, 02:50 PM   #1
kark0202's Avatar
Water tank drain plug
I lonst the cap to my water tank holding drain. Anyone know something that could fit in case my newly ordered doesnt artive befpre my next trip i need to bring water on this week?
2013 grey wolf 27bh
kark0202 is offline   Reply With Quote
Old 08-01-2016, 11:30 AM   #2
I put a valve on mine so I could drain easier. That plug valve just wasn't functional. Any hardware store can help you.
2016 Grey Wolf 26DBH
Ram 2500 5.7 Hemi 4WD
gconley is offline   Reply With Quote
Old 12-06-2016, 07:17 PM   #3
lomax's Avatar
I put one of these on mine as the CAP seemed to be a hassle and could get lost. It seems to work just fine.
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
Marc
lomax is offline   Reply With Quote
Old 12-19-2016, 12:18 PM   #4
On our 26RR, the fresh water drain is DIRECTLY over the front axle, pulling the cap is an instant washdown!! I took the cap off, replaced it with a plastic elbow and extended out to the side of the frame and attached a quarter turn valve on the end. This way, I can lean down - open the valve and drain the tank without getting soaked or having to crawl under the trailer. The 1/2" line is higher than the black/grey water drains, so no chance of dragging it off. Just my nickels worth ~
extxn is offline   Reply With Quote
Old 01-18-2017, 08:18 PM   #5
Gold Tee Box
Teetime's Avatar
http://i.ebayimg.com/images/i/111730...-1/s-l1000.jpg
Mine take a 1/2 PVC cap or shut off. You can get these from any hardware store. They are threaded 1/2 inch on one end, and ready to connect PVC piping on the other if you were using them for household plumbing...sure makes it easier than messing with caps. I replaced all mine.
Success is hiring someone to mow your lawn so you can play golf for exercise.
2018 GMC 2500 Duramax Denali
2018 Coachman Freedom Express 287BHDS
53 campgrounds/362 nights, 18K Miles since 2015
Teetime is offline   Reply With Quote
drain, tank, water, water tank
