09-23-2019, 10:08 PM
What is this and why?
Just noticed this grey tube poking out on the left side under the slide out. Is this missing a cap. Or is it a vent? Was dripping water this past weekend so I’m wondering where it goes. 2018 26DBH.
Nights Camping:
2018 - 44
09-23-2019, 11:03 PM
Phat Phrog Stunt Crew
could it be a drain for the frig?
2014 Wildcat 327ck
09-24-2019, 04:54 AM
Perhaps, weird thing is it’s on the opposite side from kitchen and bathroom which is to say that’s a lot of hose length just for a fridge drain. But maybe so to have it drip on the hookups side of the trailer.
Nights Camping:
2018 - 44
09-24-2019, 05:18 AM
Overflow for the water tank ??
2005 Dodge 3500 Cummins
2017 Wildwood Lodge 4092 BFL
1966 Mustang GT
1986 Mustang SVO
09-24-2019, 05:24 AM
$10 you have it right. Didn't even think of that.
11-30-2019, 08:27 PM
Following up from a previous post...I can't figure out what this line is. I have a 2018 Grey Wolf 26DBH. Just had it in our driveway with electric on, water connected (with a pressure regulator) and nothing else. Came home from work the next day and noticed the water slowly and steadily streaming from a grey tube on the left side under the rear of the slideout and near the wheels. Its not the fresh water drains, it is grey in color and matches the two drains from the sides of the slidouts. My questions are:
- Is it missing a fitting?
- Why would it be streaming water just with the hose attached? No water in the fresh water tank, black and grey tanks were empty.
I sent the same questions to FR but haven't heard anything back. Appreciate any feedback on it!
Nights Camping:
2018 - 44
11-30-2019, 08:31 PM
may not be the fresh tank drain but may be the fresh tank over flow. if you were hooked up to water and your bypass valve opened could of filled the fresh tank.
11-30-2019, 08:42 PM
Scoundrel
This^^^^ Its possible that unbeknownst to you, your fresh water tank is full and overflowing.
2024 Geo Pro 15TB, 400W Solar, 2 Golf Cart batteries
2015 F-150 5.0L V8 XLT Crew Cab, 4x4, Tow Package, 36 gal tank, 3.55 locker, 1891 payload, Integrated Brake Controller, Roadmaster Active Suspension
Wooden Spoon Survivor
11-30-2019, 08:50 PM
Turn off shore water.
Turn on faucet until water stops
Turn off faucet.
Turn on water pump and run water for a minute.
Turn off water
Turn off water pump once it stops.
Turn on shore water again
This should reseat the check valve and keep water from leaking into FW tank.
If this works drain FW tank.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
11-30-2019, 09:00 PM
Thank you very much....never considered the FW tank might have inadvertently filled. I will definitely try out the reset procedure this week!
Nights Camping:
2018 - 44
11-30-2019, 10:20 PM
And this is a good reminder to not go away from your R/V and leave the city water on.
12-03-2019, 12:11 AM
You may have to just take a couple bolts out of the underpinning and just follow it to the source. I’ve had to do that for a couple things. Hope this helps.
12-03-2019, 02:27 PM
Always Learning
Dollars to donuts, that's it. If the reset procedure doesn't fix it, you can add a check-valve to the system that will stop allowing water to back flow into the freshwater tank.
https://learntorv.com/water-pump-check-valve/
