Old 05-17-2012, 10:51 AM   #41
FreedomTracker's Avatar
Thumbs up
OK... I called my local Ford service dept advisor and confirmed the following:
  • OD is same as 6th gear (2012)
  • OD is most efficient gear for maximizing MPG
  • TV will NOT go into OD/6th gear when Tow/Haul button engaged
  • Cruise control (CC) makes engine work a little harder and could increase operating temp. Although not a big problem assuming correct GVWR.
CONCLUSION: for best MPG while towing, do not use CC or Tow/Haul button... If you do use CC, watch your temp guage.
2012 Ford F150 4x4, 5.0L, 3.55
2011 Rockwood MiniLite 1809s
E2 WDH 600/6000lbs
FreedomTracker is offline   Reply With Quote
Old 05-17-2012, 12:50 PM   #42
Rugged Brown's Avatar
Very interesting information, although I did suspect that I would get better gas mileage in OD. Maybe I'll use the tow/haul button less often. Use it only when the truck is searching for gears.
Terry/Bernadette
Lily the Yorkie
2019 Dodge Ram Sport 1500
2019 FR Vibe 28RL
Rugged Brown is offline   Reply With Quote
Old 05-17-2012, 12:56 PM   #43
BlakeB's Avatar
I would think a second opinion is in order. I cant imagine the "searching" for gears would be a good thing to do if you're trying to keep the trans temp down.
I guess it's all going to depend on the weight of the trailer though.
TT = 2021 ROO 233S
(Previous)TT = 2014 Palomino Solaire Eclipse 318TSBHK
TV = 2016 F-150 5.0L SCREW
Pit Crew: DW (Robin)
Kids: 9yo DD (Riley), 5yo DD (Kennedy)
Security: Boxer (Harley), yorkie (Willow)
BlakeB is offline   Reply With Quote
Old 05-17-2012, 01:20 PM   #44
Herk7769's Avatar
On the flats I press Tow Haul "OFF" let the trans upshift to OD and turn it back on. That way I get the benifit of OD and the locked transmission.
Lou & Freya the wonder dog
2019 Flagstaff 8529FL
Old 05-17-2012, 01:22 PM   #45
Lou , does it stay in OD after you do that maneuver ?
Terry/Bernadette
Lily the Yorkie
2019 FR Vibe 28RL
Old 05-17-2012, 01:32 PM   #46
Herk7769's Avatar
Yes. My RPM drops about 250 revs when I do this. It will downshift on the tow haul "step" if it needs to. On the flats it never does.
Old 05-17-2012, 04:52 PM   #47
I find it hard to believe that you can get better fuel economy with your foot as oppose to CC. It may be under high loading and mountainous terrain CC could easily have trouble managing power better than the Mark I brain/foot control. PID controllers can only do so well, especially when the feed forward is not available to CC.
However, outside of those conditions CC has got to be able to manage MPG better than the foot. I will certainly have more data about this later this summer. On the hills the Dmax/Allison/CC seems to work very well together. This might be totally different at higher altitudes and much longer grades.
I would say with a gasser, I would not be surprised if that were true. The gasser is going to spin up/shed a lot more under high load conditions. The engine is going to rev up on the hills and then shed crossing the peak and then drop very low on the downhill side. I know my Taco did that a lot in New Mexico.
Foard County News & Sassy Schoolmarm
with Lady & Chloe, 2013 39 days, 2014 59 days
2017 GD Imagine 2800BH
'07 GMC Sierra 2500HD Diesel 4x4
Why I got into RVing & More Fun
ng2951 is offline   Reply With Quote
Old 05-18-2012, 12:02 PM   #48
rotorhead1250's Avatar
I'm out here in NM and I mostly drive without cc on, just to take advantage of a little downhill assist. My diesel egt's get a little hot trying to maintain speed with the cruise on when going up hill, so I just prefer to drive it using the ol foot. Keeps me focused too. Constant scan of the gauges.
rotorhead1250 is offline   Reply With Quote
led pad
