Old 06-14-2015, 06:17 PM   #1
White drainage hose question
Was empyting my fresh tank from the valve under the trailer and noticed a second white hose next to it. No valve on this one. Just a hose cut at a 45 degree angel next to the drain valve. Any idea what the is?
Thx!
BigPatCal is offline   Reply With Quote
Old 06-14-2015, 06:18 PM   #2
Half-Timer
Fresh water tank vent/overflow
Enjoying God's creation each day.
2015 Ram 3500 Laramie Limited with 6.7L Cummins Diesel
Forest River Sierrra 378FB
ptylerp is offline   Reply With Quote
Old 06-14-2015, 06:27 PM   #3
davel1971's Avatar
what he said
David & Lynn
Old 06-14-2015, 06:35 PM   #4
Excellent. Thank you.
Old 06-14-2015, 06:36 PM   #5
Taranwanderer's Avatar
+2. The only other thing I'll add here is this: as you observed, it doesn't have a valve, it's just an open hose that overflow drains the FW tank when it gets too full and allows air into the tank as you use water (so you don't create a vacuum inside the tank and possibly collapse the tank in on itself.) But what I found (both with my previous camper and my current one) is that when I would fill up my FW tank at home and then head out on the "up and down, up and down" interstates around here--by the time I got to where I was camping, I would often have lost a third of the water in the tank out the vent (like, it said "full" when I left home and said "2/3" when I got where I was going.) So I added a valve on the vent/overflow hose as well to keep the water in. You just have to remember to open it when you get where you're going.
2015 XLR Hyperlite 30HFS5 (mods being performed regularly)
2009 Salem LA 292fkds (gone)
Nights- ('12)23 ('13)23 ('14)15 ('15)31 ('16)27 ('17) 20
2016 Ford Fusion Titanium (gulping gas again, camping support vehicle)
2014 Harley Davidson FLHX (XLR cargo)
2011 Ram 2500 CC 4X4 CTD, B&W Companion (toy hauler hauler)
Taranwanderer is offline   Reply With Quote
Old 06-15-2015, 12:27 PM   #6
Great advice - thank you!!
drain
