Old 01-20-2019, 03:40 PM   #1
JodyandMike
Why is our slide raised?
The big slide in our main living area, containing a u-shaped table and jackknife sofa, is on a raised platform. Iíd like to chuck both the booth (waste of space for just two of us) and the sofa (too small to lie on and no reclining). But Iím wondering if we can ditch the platform, too, so that it is nearly even with the main floor.
Any idea if there might be any mechanical/electrical items under the booth? I know there is nothing under the sofa but the frame, as it is accessible from outside. Iíd check myself, but itís at a seasonal site and we donít have access right now.
The picture below shows what Iím talking about. Thanks!
Jody and Mike
Twin Cities, Minnesota
2016 Cherokee Grey Wolf 29DSFB
jodyminn is offline   Reply With Quote
Old 01-20-2019, 03:56 PM   #2
You can't.
There's rollers under there, plus a flange that your slide uses to stop. Probably some other structural items.
You won't be able to modify the outer shell of your slide without significant other modifications to the rest of the unit.
2018 FR NoBO 19.5
2018 F150 XLT, 5.0l ,3.55's
blackfly is offline   Reply With Quote
Old 01-20-2019, 04:03 PM   #3
fonzie's Avatar
You most likely have above floor slide mechanism, like Blackfly says, there would be a fair amount of modifications to do.
File Type: pdf Lieppert Above Floor Sofa Slide-Web.pdf (1.09 MB, 74 views)
Fonzie
Nights Camped:2012(36) 2013 (17) 2014 (18) 2015 (18) 2016 (36) 2017 (32) 2018 (42)
Old 01-20-2019, 04:22 PM   #4
PPST Wannabe
kenandterry's Avatar
Nope......you canít ditch the raised platform to level.
However......you could tell others that you have a sunken living room in your rig.
All the manufacturers are trying to be first with the next new idea.
Just sayiní.
Ken and Terry
2010 Georgetown 330TS being pushed by our
2017 GMC Terrain toad (4 wheels down)
kenandterry is online now   Reply With Quote
Old 01-20-2019, 04:50 PM   #5
JodyandMike
Lol!!! Thanks for the info, guys, before I had DH drill a hole!
Jody and Mike
Old 01-20-2019, 05:06 PM   #6
Lacey's Spring, AL
formerFR's Avatar
it’s the ‘floor’ of the slide, without it you’d have no way for the furniture to slide out with it - it also adds the structural integrity to the slide room ‘box’ ...
you can always buy an Airstream with no slides ( :
The Turners
'14 Thor Palazzo 33.3 diesel
KingTailgater2 Dish, 100w/5amps roof SOLAR, BlueOx, 100,000+mi since '14... US, Alaska, and Canada... from W.C. Georgia, then W. North Carolina, now Lacey's Spring, AL : )
formerFR is offline   Reply With Quote
Old 01-20-2019, 05:08 PM   #7
Lacey's Spring, AL
formerFR's Avatar
or you can order a Newell - built from scratch, custom, and the slide floors are ‘flat’... get up a good downpayment, and wait several years for it to be built
Old 01-21-2019, 02:48 PM   #8
Terry Luther's Avatar
raised slide
I asked about that at my dealers. The light weight units have the slide mechanisms above the floor level. therefore you cannot lower it.
Fortunately I have the heavier Cherkee and was able to do mods to mine.
Old Hunter
Retired from the USAF in 1979,
Build porch swings to stay busy when not hunting.
Cherokee 264 DBH
Ram 1500 double cab TV.
Terry Luther is offline   Reply With Quote
Old 01-21-2019, 02:55 PM   #9
Still doesnít mean you canít ditch the booth and sofa and mod on top of the box..
2016 Siverback 33IK
Old 01-21-2019, 03:57 PM   #10
I'd take the booth and sofa out - add a couple of rocking, reclining chairs and an adjustable table and ta-da, new camper!
Yes, you will have to take in consideration the raised floor, but if you can findnsome low chairs, that will make them about the right height. If the table is ADJUSTABLE, that can also adjust with the height.
merrykalia is offline   Reply With Quote
slide
