Old 11-23-2018, 07:42 PM   #1
Windows Fogging Up
Hey All,
I have a 26DBH and was wondering what people do to prevent windows from being fogged up in the morning, even when heater is being used.
leonards is online now   Reply With Quote
Old 11-23-2018, 07:59 PM   #2
PPST Wannabe
kenandterry's Avatar
Move to warmer climates????
Ken and Terry
2010 Georgetown 330TS being pushed by our
2017 GMC Terrain toad (4 wheels down)
kenandterry is online now   Reply With Quote
Old 11-23-2018, 08:03 PM   #3
run a dehumidifier. your unit is prob very humid and the moister goes to the coldest spot aka your single pain windows.
Kimber45 is offline   Reply With Quote
Old 11-23-2018, 09:37 PM   #4
I have found in ours, in cold weather, the windows will get condensation on them early in the morning before sunrise no matter what we do. We monitor the inside humidity and try to keep air moving inside the trailer. We use an electric space heater to supplement the furnace. Even when the humidity in the trailer is 55-60% the windows will get condensation on cold nights. Turning the fan to low on the thermostat while the furnace is on helps.
2015 Cherokee 274DBH
2015 Ram 3500
klrobert is offline   Reply With Quote
Old 11-23-2018, 09:41 PM   #5
Ret E-9 Anchor-clanker
donanddona's Avatar
You can crack open a ceiling vent to help remove the moisture. Ceramic elect heaters add to the moisture. See if your furnace will operate the "Fan only", use only during the noon time so you won't confuse when your furnace will need to run, then you can switch it back to auto.
donanddona is offline   Reply With Quote
Old 11-23-2018, 10:38 PM   #6
I donít know if the fan and the furnace can run simultaneously
window
