Old 11-03-2018, 06:26 PM   #1
Winterize
If I use the city water connection to blow out my system will I still have water in my pump lines and inline filter? 2019 cherokee 26dbh
farmboy6180 is offline   Reply With Quote
Old 11-03-2018, 06:31 PM   #2
yes. do you have a pick up tube to pump anti freeze into the pump?
Kimber45 is offline   Reply With Quote
Old 11-03-2018, 06:32 PM   #3
It's a bitch to get to. That's why I'm wanting to blow out
Old 11-03-2018, 08:13 PM   #4
dbledan's Avatar
Yes. I removed my filter for this reason. Only have to get to it once that way. I blow the lines out as it starts to get cold but still winterize with pink stuff when I am done for the season. I use an inline filter at the hose now.
dbledan is offline   Reply With Quote
Old 11-04-2018, 05:10 AM   #5
What if he has never used his pump?
I winterized yesterday and I only drained the hot H20 tank, blew out the lines and added the pink stuff in the traps. 26dbh Grey Wolf....
Should I do more?
Thanks.
Lukegsdaddy is offline   Reply With Quote
Old 11-04-2018, 11:50 AM   #6
dbledan's Avatar
Should I do more?
Thanks.
If you have a filter you will want to remove it.
If you have water in the screen before the pump remove that as well.
If you have a black tank flush maybe do that as well.
Pink stuff is a personal choice. I am just not that confident in blowing out the lines alone.
Old 11-04-2018, 07:37 PM   #7
I have heard a couple issues if you don’t use the pink stuff. The pump can have water in it. Even if you never used it could still be in there. And it can freeze and crack. Second hard to get all the water out of the low points in the line.
ChrisMoore is offline   Reply With Quote
Old 11-04-2018, 07:39 PM   #8
BandJCarm's Avatar
I blew out the lines last year. It did not get all the water out.
I just finished winterizing. But.........senility struck! I forgot to remove the water filter. I'll take it out tomorrow.
FROG AR-0019-242
BandJCarm is offline   Reply With Quote
winter, winterize
