Old 11-08-2018, 02:44 PM   #1
Winterize Water Heater
I am winterizing today, an inch of snow forecast for tomorrow.
I plan on using the camper in a month or two on a trip to Tennessee and then Florida, so I prefer to use the method to blow out the water with compressed air and use as little RV anti freeze as possible.
I first wanted to bypass the water heater. See attached pic. Sure looks like all 3 faucets are in the open position. Just want to see what you think, why would anybody do this? I bought this camper used a few months ago. I never used the water system because I needed to keep the weight down.
Questions:
1. Where do you get fresh water when you get near your destination?
2. Do I just need to close the in/out valves since the bypass is already open?
3. I am having a hard time getting my hot water heater drain plug back in. It was unscrewed, so the threads may be damaged slightly. Do you know what size tap/die is required? I just want to clean up the threads. I tried a dremel tool with a wire wheel already.
Thanks for the help!
RCSP is offline   Reply With Quote
Old 11-08-2018, 02:47 PM   #2
I couldn't add a 2nd picture, the upload fails so here it is.
Old 11-08-2018, 02:52 PM   #3
Yea, those valves aren't set right for anything. If you want to bypass the WH, turn the top and bottom one both 90 degrees.
Iwritecode is offline   Reply With Quote
Old 11-08-2018, 02:58 PM   #4
cavie's Avatar
All your valves are open. To bypass the heater to winterize you need to close the two valves closest to the heater. To dewinterize and use the heater, you need to open the two valves closest to the heater and close the one in the middle.
All three should never be in the same position.
2002 27rk Wildcat 5er.
Port Charlotte Fl/Hinsdale Ma
Retired Master Electrician.
cavie is online now   Reply With Quote
Old 11-08-2018, 02:59 PM   #5
Head Rambler
The Anode rod threads are 3/4: NPT. They can be a bit of a pain to get them to rethread in correctly because the rod wants to tilt down causing the fitting to cross thread. You have to hold the socket at an angle to get the threads to start correctly. I usually place a thin nut in the socket behind the rod fitting so that it won't recess into the socket too far.
I prefer to use a pipe tap to clean up the threads, but you have to be careful not to cut new threads, but just chase the ones that are there.
As for the bypass valves , it does appear that the bypass valve is set to bypass and the inlet and outlet valves are set to normal flow. Just turn the inlet and outlet valves 90 and that will bypass the water heater.
Gotta go campin!
Bama Rambler is online now   Reply With Quote
Old 11-08-2018, 03:03 PM   #6
cavie's Avatar
Questions:
I don't think the threads are stripped. The weight of the anode not is pulling down and making it difficult to get started. Put a lot of pressure on the bottom with your fingers to get it to go in straight.
Old 11-08-2018, 03:16 PM   #7
Thanks for all the help, you all rock!
Old 11-15-2018, 07:41 PM   #8
I cannot find any examples online of the way mine is set up - two valves, but one is at the junction of the hot water and the bypass? Have I done this correctly?
Closeup of bottom (cold) valve:
Any advice is appreciated. Thanks in advance.
Vel
velvethippie is offline   Reply With Quote
Old 11-16-2018, 02:18 AM   #9
wmtire's Avatar
Vel
Howdy Vel, your picture links do not work. You probably need to upload the pics to the thread, instead of linking.
This thread has several pics of different winterizing/bypass valves. Can you see if yours is like any of them?
NO (OR LUKEWARM) HOT WATER -Please read first
2011 Flagstaff 831 RLBSS
I hate it when people don't know the difference between ur and u'r!
Old 11-19-2018, 07:55 PM   #10
I was able to get it sorted out eventually by trial and error, but take a look at this interesting setup:
2017 Cherokee 274VFK
2008 Club Car Precedent
2003 Ford F-350 7.3L Super Duty w/ Air Lift
heater, water, water heater, winter, winterize
