Old 10-14-2012, 09:16 PM   #11
PHS79's Avatar
Originally Posted by SJones42 View Post
if it gets real cold where u are it might be a good idea to pull the battery and keep it someplace warm.Nothing worse than finding a puffed up battery in the spring because it froze up on ya.
Hopefully it only gets as cold as it did last year, only 3-4 days below 0*. But yes after next weekend when we finish pulling everything out of the camper, the battery will be put in the shop (where it is a min of 45* in the winter) and put on the battery tender.
One good thing that I did find when I was installing the winterizing kit, I found where the mouse got into the camper last winter. He came up from above the grey water tank and entered right next to the shower drain, so I will be trying to seal that area up and also putting some mouse traps in that area just in case also.
TT-2013 Passport 3220BH
TV-2004 F150 FX4, not exactly stock...
nights camped:
with 2001 Kodiak K215: 2010-10, 2011-12
with 2012 Grey Wolf 26BH: 2012-19, 2013-24, 2014-11, 2015-6
with 2013 Passport: 2015-13, 2016-15 booked
PHS79 is offline   Reply With Quote
Old 10-21-2012, 08:39 AM   #12
One of the best ways i found to keep mice out is to find the hole,put a piece of the heavy steel wool in it and spray foam it .Mice will not chew through the steel wool.
2012 Ram 2500 HD 5.7 Hemi
2013 Forest River Cherokee 254Q
SJones42 is offline   Reply With Quote
