Old 09-10-2018, 08:39 AM   #1
flashtilley's Avatar
Winterizing Grey Wolf 29BH
Hi, anyone have any experience winterizing a 29BH? I havenít looked yet to see if there is a winterizing kit installed (hose and valve to suck antifreeze). Any tips with this unit? Does the winterizing kit come installed from factory?
Thanks!
flashtilley is offline   Reply With Quote
Old 09-10-2018, 08:48 AM   #2
cherokeewolf's Avatar
My 2018 29BH did not come with a winterizing kit. Water pump is at the bottom of my pantry which is accessible thru a removable panel. I did install a winterizing kit at the pump as well as a door for quick access.
Typically I use an air compressor to blow out my lines from the city water connection and then fill all lines with RV antifreeze using bypass kit and water pump Click image for larger version
ID:	185981Click image for larger version
cherokeewolf is offline   Reply With Quote
Old 09-10-2018, 09:03 AM   #3
Typically I use an air compressor to blow out my lines from the city water connection and then fill all lines with RV antifreeze using bypass kit and water pump Attachment 185981Attachment 185982
Thanks. Iíll have to get the kit installed. What about the hot water bypass lever? Is there one somewhere?
Old 09-10-2018, 09:24 AM   #4
On my unit the hot water bypass is at the HWH. Access was from under the front bed but also made an access door thereClick image for larger version
ID:	185986Click image for larger version
Old 09-10-2018, 02:46 PM   #5
BooBoo23's Avatar
The bypass valve(s) are on the back side of the WH, There will be a removable panel on the back of the WH, there are no levers, there are valves and depending on your RV there could be 1,2, or 3 valves. Many videos on the subject on You Tube.
2014 Palomino Puma 25RS
2011 F-150 Super Crew XLT
Days camped in 2014 - 23 Camped 2015-47
Camped 2016-71, 2017-33, 2018-29 booked
KT4W
BooBoo23 is offline   Reply With Quote
Old 09-11-2018, 06:59 AM   #6
Thanks. I know there are a lot of videos but my question is specific to the 29BH model.
Old 09-11-2018, 07:09 AM   #7
You'll find multiple TT's that use the same basic setup as the 29BH. Had a 07 Jayco and now have a 2018 Cherokee and I still do basically the same thing to winterize the Cherokee as I did on the Jayco.
TheWolfPaq82 is offline   Reply With Quote
Old 09-15-2018, 01:26 PM   #8
So I bought the camco winterizing kit and was going to install it today in my 29BH. The install never happened as Iím not entirely sure how it connects to the vacuum end of the pump. The pump has this black thing attached as per my pics. Iím not sure how to take it off or connect the new valve to it. Can someone whoís done this before offer some help. I donít want to call the dealer. Click image for larger version
ID:	186539Click image for larger version
ID:	186540Click image for larger version
ID:	186541Click image for larger version
ID:	186542Click image for larger version
Old 09-15-2018, 03:01 PM   #9
The black thing with the label on top is a water filter (the side should be clear and have a stainless steel wire mesh inside of it.
ID:	186555   Click image for larger version
carbuthn is offline   Reply With Quote
Old 09-16-2018, 03:47 PM   #10
Thanks. I should be able to just unscrew it from the pump and install the winterizing valve?
Old 09-16-2018, 03:49 PM   #11
It looks like I can just leave that on there and remove the white hose from it? Problem is I only got about 3Ē before that hose goes down into the floor and then covered with spray foam. How does that metal hose clip come off?
Old 09-16-2018, 04:22 PM   #12
I ended up cutting the white tube to put in the tee. Your going to need some hose clamps and barbed hose connectors to connect the hoses back. I ended up getting it all at the hardware store. Take the tee with you so you can get the barbed ends that thread on to each side, make sure you get the right size for the hose. There are several types of clamps pick the ones you are comfortable with. When ready to install just spit on the barbed end to slide the tube on easier.
Bedlinedf250 is offline   Reply With Quote
Old 09-16-2018, 05:11 PM   #13
Thanks! I think Iím gonna need to buy some more white hose. Like I said I only got about 3Ē to work with then it goes down the floor. This could be a challenge. Not sure why they didnít spare more hose there.
Old 09-16-2018, 05:18 PM   #14
If you splice the hose and install the tee connector remember it's going to add to the length. I didn't have to add any tubing.
Old 09-16-2018, 06:27 PM   #15
The metal ring is a stainless steel pex clamp. They are crimped onto the hose and fitting. They have to be cut off normally. The fitting maybe unscrew from the strainer (depends on the strainer).
Also you may have some extra hose under the floor, but you will need to pull out some of the foam to tell. A can of foam is 4 - 5 dollars. I normally try to use up the can. You often have spaces underneath that can be filled.
Old 09-16-2018, 07:07 PM   #16
Not a newbie
Johnfort's Avatar
Disconnect the hose from the filter and install the valve in the end of the hose. Then add 18" of hose to the other end of the valve and loop it back into the suction side of the strainer (filter).
Johnfort is offline   Reply With Quote
Old 09-16-2018, 07:09 PM   #17
Not a newbie
Johnfort's Avatar
THAT'S why I get the "big bucks".
Old 09-16-2018, 07:33 PM   #18
Thanks for the tips guys! This really helps!
Old 09-16-2018, 07:39 PM   #19
Btw, is it normal for the manufacturer to leave that much mess in there? Looks like they forgot to vacuum it out.
Old 09-16-2018, 07:53 PM   #20
bikendan's Avatar
Yep, pretty darn normal.
Equalizer WDH
grey wolf, winter
