Old 10-15-2018, 07:44 PM   #1
Winterizing hose
I have a 2015 Cherokee, first time winterizing and it didnít come with a hose. Can you buy one at a Rv place? Or is that something you have to put together yourself? Anyone know what size female fitting I would need for my pump?
Birdfan80 is offline   Reply With Quote
Old 10-15-2018, 08:01 PM   #2
You can pick up a winterization kit from any rv dealer or on the web. If your unit doesn’t have the by-pass (although I have never seen one without although there probably are) then you’ll need to do that too. Otherwise, the kit Is super easy to add and I believe the thread sizes are standardized. Once you’ve got that it’s pretty straightforward with great advice on here and YouTube. Cold weather kinda sucks, doesn’t it :-)
2016 Berkshire XL 40A towing 2016 Jeep Wrangler.
Prior to this Jayco fifth wheel: 24' Eagle, 30' Designer, and 40' Jayco pinnacle.
Igave is online now   Reply With Quote
Old 10-15-2018, 08:04 PM   #3
Originally Posted by Igave View Post
You can pick up a winterization kit from any rv dealer or on the web. If your unit doesnít have the by-pass (although I have never seen one without although there probably are) then youíll need to do that too. Otherwise, the kit Is super easy to add and I believe the thread sizes are standardized. Once youíve got that itís pretty straightforward with great advice on here and YouTube. Cold weather kinda sucks, doesnít it :-)
You bet! Thanks
winter
