Old 02-13-2019, 05:00 PM   #1
Winterizing Question
Would it be okay to only blowout the lines, then add antifreeze to the p-traps and drains? I've always had the dealer do it and they run antifreeze through the lines. I will be doing it myself next winter and just want to make sure.
Also, would I gain anything from draining the lines after each use? We go about 6-8 weeks in between trips during the summer. Thanks.
2017 Cherokee Grey Wolf 26BH
navman28 is offline   Reply With Quote
Old 02-13-2019, 05:05 PM   #2
Locky's Avatar
A lot of people do that so you should be fine. I blow out my lines and suck antifreeze through them plus put it down the sink and shower drains along with leaving some in the toilet. Don't forget about the outside shower if you have one.
2018 Rockwood 2906WS
2013 Chevy Silverado
1967 Beautiful Wife
Locky is offline   Reply With Quote
Old 02-13-2019, 05:15 PM   #3
Thanks. Should I drain the lines in between trips? I havent been, but wondering if I should.
Old 02-13-2019, 05:40 PM   #4
I drain my tank and low point and water heater if my unit is going to be sitting more then a couple weeks to prevent stagnate water sitting around in the tank/lines
Kimber45 is offline   Reply With Quote
Old 02-13-2019, 05:45 PM   #5
cavie's Avatar
Not in the summer.
2002 27rk Wildcat 5er.
Port Charlotte Fl/Hinsdale Ma
Retired Master Electrician.
cavie is online now   Reply With Quote
Old 02-13-2019, 06:23 PM   #6
I blow mine out and put antifreeze in the p-traps. The key to blowing the lines out is give them plenty of time to make sure you get all the water out. Also, the bigger the tank on the compressor the better. I have a fairly small one and have to wait for the tank to completely fill back up before doing the next line.
For me, I blow every line, then go back through and do each one again one more time just to be sure. The easiest one to forget is the outside shower.
This has worked for me and I live in Colorado where temperatures are usually below freezing every night. Just be thorough and careful.
joeuncool is offline   Reply With Quote
Old 02-13-2019, 06:26 PM   #7
I also do this for the same reason. It is so easy to do that I made it part of my normal after camping unpacking process.
Old 02-13-2019, 10:59 PM   #8
I was thinking I should be draining it in between trips. Guess I will add it to the checklist. Thank you everyone for the help.
Old 02-20-2019, 09:04 PM   #9
What about filter on pump inlet?
farmboy6180 is offline   Reply With Quote
Old Yesterday, 11:46 AM   #10
Everything I've read says to remove the filter before pumping antifreeze through. But I dont have one on and next winter will be my first time.
winter
