Old 07-22-2019, 05:11 PM   #1
Wolf pup low to no cost mods
Much wasted space and access in my 2019 Wolf Pup Limited.
First, all the added inside cabinet and bins are slapped in at angles, in the overhead cabinets, under the sink and inside the forward under bed storage. Cutting and reinstalling them squared off produces a lot more storage.
Over the radio is a blanking panel that can be removed to gain more space. I placed a plastic tray on top the radio in that area.
Under the stove top burners and above the gas heater is a HUGE space with one little gas line running through it. It is blanked off on the face and has a divider panel between there and the under sink area. Removed them both.
The overbed front cabinets are a bear to reach into the outer 25% on either side of the doors. I popped out those blanking panels and added bungee straps across the openings, installing tapered file bins from WalMart office supplies to fit into the TT rounded front.
Last, I took the face panel off the forward dinette bench, put a couple wood braces into the bench frame halfway in and installed the face panel in there. Instant shoe bin, no more tripping over shoes or stepping on them under the table.
ID:	210551   Click image for larger version
ID:	210552   Click image for larger version
ID:	210553   Click image for larger version
ID:	210554   Click image for larger version
2019 Cherokee Wolf Pup 16BHS
2019 Ford F-150 S-Crew 5.5 bed V8 w/tow package
Husky Centerline TS WDH 400-600# spring bars
2018 16 days camped, 2019 9 days so far.
Boomerweps is offline   Reply With Quote
Old 07-30-2019, 06:30 PM   #2
spooky
Hi. I have done all you mentioned but seat storage. Great idea will look at. Also converted shower/bath into closet. Have a question do you know how to manually move slide out in case of power failure? Thnx. Dan
rekaj321 is offline   Reply With Quote
Old 07-31-2019, 12:09 AM   #3
Maticuno's Avatar
“Here is your country. Cherish these natural wonders, cherish the natural resources, cherish the history and romance as a sacred heritage, for your children and your children's children. Do not let selfish men or greedy interests skin your country of its beauty, its riches or its romance.” - Theodore Roosevelt
TV: 2003 F250 V10 4X4
TT: 2019 Wolf Pup 18TO Black Label
Maticuno is offline   Reply With Quote
wolf pup
