Old 01-06-2019, 10:33 AM   #1
Wolf Pup Roof Question
Hello, I have a 2017 wolf pup. Is the roof considered a walk on roof and will support the weight of an individual? Thank you
KenS999 is offline   Reply With Quote
Old 01-06-2019, 11:34 AM   #2
Short answer, yes.
One of the many reasons I chose my Wolf Pup 16BHS was the walk on roof. I watched a detailed Utube review of the TT from Haylett RV.
I still gingerly walked on mine when installing the cover for winter
2019 Cherokee Wolf Pup 16BHS
2019 Ford F-150 S-Crew 5.5 bed V8 w/tow package
Husky Centerline TS WDH 400-600# spring bars
2018 16 days camped, 2019 9 days so far.
Boomerweps is offline   Reply With Quote
Old 01-06-2019, 12:02 PM   #3
rsdata's Avatar
RV roofs are generally OK to walk on with soft sole shoes... if you are worried then put up a 3/8" or so thickness of plywood about 2 foot square to distribute the load a bit
ďToo much of anything is bad, but too much good whiskey is barely enough.Ē Ė Mark Twain
2014 Shamrock 183
Old 01-06-2019, 08:58 PM   #4
Thank you for the helpful input. Ken
Old 01-07-2019, 06:36 PM   #5
robin amd jan with ziva
Be ware the roof trusses are only 1x2 and on mine they cut through one in two places for vent pipes substantially weakening that truss such that when I had to have a new roof due to water damage which wasn't discovered by the dealer that sold it to me and won't cover the replacement . My understanding is that if it doesn't have a ladder it isn't a walk on roof. Hope you have better luck than we have.
Robin and Jan with Ziva is offline   Reply With Quote
Old 01-09-2019, 06:09 PM   #6
K2Kevin's Avatar
I also have a 2017 Wolfpup and have been on the roof a few times a year to clean and inspect. I am very careful where I step and you wont see me jumping on it anytime soon. Theres a lot crammed on that small room so stepping on or tripping on something is easy. Be careful...
K2Kevin is offline   Reply With Quote
roo, roof, wolf pup
