Old 09-24-2018, 07:20 PM   #1
Wolf Pup wiring diagram
Anyone have a wiring diagram for a 2017 Wolf Pup BHS. Tomorrow Iím going to install some lights above the sink and above the dinette. Got these really nice duel LEDís that will light this little TT up. Could not find a diagram in the search field so I thought I would throw the question out, thanks.
Peprice is offline   Reply With Quote
Old 09-24-2018, 08:42 PM   #2
rracer5's Avatar
You will never find a wiring diagram anywhere. These units are built "freehand" on the assembly line by several technicians and craftsman who have their own way of installing their components. They pull whatever wires they need & cut and splice as they see fit .
2014 Sanibel 3250
rracer5 is online now   Reply With Quote
Old 09-25-2018, 07:59 AM   #3
K2Kevin's Avatar
I used led touch sensitive lights on the two spots you mentioned. I plan on replacing them with hard wired lights eventually, maybe, maybe not.
Over counter should be easy, I have a feeling youíll find wires in the base of that cabinet. Should be easy to pry up the base and take a look. Let us know what you find on your expedition.
K2Kevin is offline   Reply With Quote
Old 09-27-2018, 05:23 PM   #4
K2Kevin's Avatar
I should also add... Installed a very inexpensive led light strip under to the cabinet last year. It runs off of usb (you can see powered at outlet) and may try to hard wire a nicer set in the future. This was just a very cheep Walmart $4 led with remote, lighting is actually ok, but the led density isnít great, and my placement could have been better.
Old 09-27-2018, 07:46 PM   #5
It is done and have pics I will post later. No wires were found either in the crevice of the lower part of the cabinets I was surprised.
Old 09-27-2018, 08:45 PM   #6
K2Kevin's Avatar
Iíve been very tempted to start popping out panels all over this thing just to know where I can find power for now and future.
diagram, wiring, wolf pup
