Old 01-23-2012, 08:15 AM   #11
ken0042's Avatar
Ray, where on the axle should I look to see the weight rating?
DC- one thing I noticed that is different from your picture compared to mine; I appear to have a couple of red wires running along the axle towards the wheel. (Probably for the brakes.) Makes me wonder if something is different.
The other consideration; is it possible that because I'm in Canada that the trailer was built differently to satisfy Transport Canada? I don't know; just trying to figure out why I haven't had an issue. It would be nice if we could narrow down what all the affected units are.
Wolf Pup T16P owner
"The trouble with quotes on the Internet is that it is nearly impossible to discern if they are genuine." - Abraham Lincoln
ken0042 is offline   Reply With Quote
Old 01-23-2012, 08:28 PM   #12
The wires would be for the brakes. I can't imagine anything being built differently between the campers because yours was purchased in Canada.
I'm in communication with Lippert now and I've sent several photos so I'll post back when I find out any more information.
2010 Nissan Frontier Pro-4X 4x4
2011 Wolf Pup 17B
dc326 is offline   Reply With Quote
Old 02-01-2012, 08:19 PM   #13
I haven't seen any trouble with my 16p so far. The tires are square with the trailer and no signs of wear. I haven't traveled with water in the tank as I use a campground with water hookups. I've had my trailer for a year now I will keep an eye on it though.
sgharp is offline   Reply With Quote
Old 02-14-2012, 01:14 AM   #14
I liked the Wolf Pup on the web, but couldn't find the interior height. Also what vehicles are people using to pull the Wolf Pup (16P)?
merry camper is offline   Reply With Quote
Old 02-14-2012, 07:55 AM   #15
I'm 5'9" and have plenty of head room. It's not a really wide trailer though. I just barely fit lying in the bed. I pull mine with a full-size Chevy truck (silervado) and I don't even know it's behind me. I use a brake controller but do Not have a WD hitch. The truck doesn't squat at all when I hook it up.
Old 02-15-2012, 06:46 PM   #16
ken0042's Avatar
Merry Camper- my interior heights are as follows:
Door height- 70.5"
Interior ceiling height- 75"
Interior height; floor to lights and A/C- 73"
There is also a great thead about general Wolf Pup stuff here: Wolf Pup
(This one is about the axle issue.)
Wolf Pup T16P owner
Old 02-21-2012, 06:38 PM   #17
Here's an update. I ended up emailing and speaking to Lippert directly. I'm going to take it back and install another axle. Hopefully this one solves the problem.
2011 Wolf Pup 17B
Old 02-27-2012, 12:58 PM   #18
Forest River really came through for me!
Forest River installed a 5200 lb torsion axel and 225x15 Radial 8 ply tires/wheels on my Wolf Pup 16P - Charged a very nominal "Upgrade cost" and now I have about 2" more ground clearance and perfectly straight (very heavy duty axel/brakes/bearings Etc.
Remember when you carry 50 gallons of water it adds 450lbs - You could easily have over 4000lbs of total weight.. I reccommend a good tow vehicle for the Wolf Pup - at least 5000lb tow capacity...
Ray
sagegray is offline   Reply With Quote
Old 02-27-2012, 01:01 PM   #19
I reccommend a tow vehicle with at least 5000lb tow rating for the Wolf Pup...
It is heavier than it says and you can add a LOT of weight 50 gal of water alone weighs 450lb...
Old 05-29-2012, 09:59 AM   #20
had one axel replaced last year, same prob again this year, looking into the 5200 upgrade
padk125 is offline   Reply With Quote
axle, bent
