When I rewire my battery to add 2 6V batteries and add solar, the converter, solar and trailer connector will go straight to the battery bank, through two circuit breakers that you can switch off. The additional main battery disconnect will be between the battery and the loads only. This way, you can charge with no loads on.
Seems silly to have a battery disconnect that prevents you from charging the batteries. Mine is for a trailer but wondering why it would be any different for a motorhome.
