My end issue is no 12v power to the coach. Since the relay does not close and make contact, all 12v power is stopped at that point.
Definitely sounds like a bad relay. There is also a circuit board that controls those relays.. could be a number of things. You obviously have power coming into the isolator/disconnect. Here's the isolator/ battery disconnect itself I found on line.
Slim, RVing 30 plus years
2015 Dynamax DX3 37 RB
That sure looks like it. Before I buy one, I want to put auxiliary power to the relay to see if the soleniod is possibly bad. But you are right that it may be the circuit board.
Dan Burkhart
2015 Dynamax DX3 TSR
