05-21-2017, 07:11 PM
$2,000 for Dual Satellite System and It's Hooked Up Wrong
So MotorHomes2Go charged $2,000 to install the DirecTV Trav'ler system to work with the In-Motion system off A/B switches. It all works but they installed on an outlet that isn't powered off the inverter. So once you're in motion, the In-Motion system stops working. Oops, BIG oversight by the installer.
It looks like the power inserter for the In-Motion and the main DirecTV box both need to be up front above the cab where there's constant power and not in the bedroom behind the TV where there isn't.
I sure didn't get my $2,000 worth, did I?
How do you think the dealer should handle this?
Should I ask for a partial refund since now I need to fix this myself?
Andy & Debbie Shultz
Harrisburg, PA
2021 Dynaquest XL 3801TS
05-21-2017, 07:16 PM
I would ask, knowing what they will say. Hard to believe these things happen when you spend so much money with them.
2023 Dynaquest XL 3700BD
Had...2018 Force HD, 2016 Force, 2014 Thor 33sw
05-21-2017, 08:38 PM
Yep Halla. I don't expect much, but maybe I'll be pleasantly surprised.
I don't think it will hurt to leave the Trav'ler power inserter in the back. It will only be used when on shore power.
Just need to switch the splitter around for the In-Motion side on the roof because the pass through power from the inserter will be coming from the other direction. It's frustrating because I'm doing work I paid someone else to do. Here's a pic of the Trav'ler up and working. Watched the Penguins win 2 games while camping this weekend in HD.
Harrisburg, PA
05-22-2017, 07:40 AM
Commercial Member
That or see about adding that bedroom circuit to the inverter... I have also seen people for low draw devices, just hook one of those power port inverters to a 12v power line. Just depends on the draw and you probably don't want to plug anything else into that since the wires would be too small.
05-22-2017, 10:36 AM
How hard would it be to add the bedroom outlet to the inverter?
Harrisburg, PA
05-22-2017, 11:00 AM
I'm not sure I follow you. The In-motion is powered by 12v, only the DirecTv box is 120v. At least that's how mine works. I ran an outlet off my inverter to run the box and a TV, but usually have the generator running anyway, so it doesn't really matter.
2016 Georgetown 364TS
2017 Jeep Rubicon Recon toad
Nights Camped 2019 - 17
05-22-2017, 11:25 AM
The power inserter for the SWM module and the DTV box both use 120v. So I'd either need to get inverter power to that outlet or move them up front where there already is. Running the genny isn't an alternative in my book.
Harrisburg, PA
05-22-2017, 01:35 PM
The worst they can say is no.
05-22-2017, 01:44 PM
We always run our generator while driving. No problem watching dish with it running.
Jaime
2014 Mirada 35DL
2016 Chevrolet Colorado Crewcab 4x4
2013 Honda CRV
Brake Buddy Stealth
05-22-2017, 04:48 PM
Schultz01,
I feel your pain - that's the main reason I do most of my own work - not because I love it, but because it will (eventually) be done right, with attention to detail that you can't realistically expect from the dealer.
I've run across a few mechanics/techs that work in the that mode all the time, but it's rare.
In any case, my 2 cents: figure out the best technical solution, then bring the rig over to them, tell them exactly how you want it fixed. You may just have to be a constant PITA for them until they make it right. I've found that in this industry, the squeaky wheel will eventually get the required grease.
Good luck getting it fixed up, let us know how it turns out.
-Greg
2018 Dynamax Force HD 37BH
AKA "Thunderwagon"
05-22-2017, 07:06 PM
Originally Posted by Ender
Shultz01,
Yep. The one time I leave it to someone else, they disappoint me. Should've known better.
Harrisburg, PA
