Current brochure states that it comes with a 10,000 # hitch. There are a lot of things to consider when towing however...so you should check everything out with a towing calculator or similar.
10k is no worries on a Force HD (33k GVWR 54k combined). Force is a 28k rated chassis, 33 Combined. You need to subtract loaded weight from the combined weight to find towing capacity. (then of course worry about tongue weight adding to the GVWR), but that's the simple math.
__________________ If "Search this Forum" does not yield answers, please post questions as a "New Thread" (instead of asking privately) so others can benefit from the answers.
It's got a 10k hitch, but just be aware that you'll have to cut into your CCC (cargo carrying capacity to use all 10k).
28k GVWR
33k GCWR
Means you need to be 5k under GVWR to use all 10k. Not sure what the dry weight is, but that'd tell you how much stuff you can carry. Need to balance CCC and GCWR.
