Old 09-15-2019, 01:31 PM   #1
LandKKnight's Avatar
20's night time, 60's day time, what to do?
I know I read about this on the forum but can't find the thread. We are going to Mammoth Lakes this coming weekend. Weather app says it will be 25 degrees at night, 60's in the day. Anything special we need to do to prevent anything bad happening to the pipes/plumbing at night? Is overnight cold long enough to worry about it? Should we simply fill the tank and not hook up to the water at the campsite? Any suggestions welcome!
(I5 30 FW 2018)
Kevin and Linda Knight
2018 Isata 5 30FW 4x4
dog-mobile for Sophie, Roxy, and Kai
Windsurf-mobile for us
LandKKnight is offline   Reply With Quote
Old 09-15-2019, 01:47 PM   #2
cboss's Avatar
At 25 at night I would not leave the hose hooked up. It would be best to put some water in the tank, disconnect the hose, both ends, and stow it. The campground may shut down the water or at least let it drip.
I don't think you have to worry about the camper plumbing unless you are going to have some strong winds during the night.
Craig & Cath
2018 2902WS Rockwood Ultra Lite
2017 Ford F250 Lariat, 6.2 gas
Equalizer Hitch w/ 4-Point Sway Control
Days camped since 2016(retirement): 669
cboss is online now   Reply With Quote
Old 09-15-2019, 02:29 PM   #3
We just came back from Tuolumne Meadows (elev. 8800') which is about an hour north of Mammoth. Tuolumne is dry camping and despite the elevation difference has very similar temperature ranges as Mammoth. You can see the RAWS data here- TUOLUMNE MEADOWS (TUM)
We had absolutely no problems with our plumbing. The temps in the early morning dropped into the 20's - 30's range they but don't stay down there. As soon as the sun comes up, so do the temps. Its the Sierras... "freeze or fry"! Never even used the tank heaters on the black/gray tanks. We started with a full tank of water and came home with a half tank and experienced no problem with that tank either.
Enjoy your time at Mammoth!
2018 DX3 36FK
2013 Jeep JKU
Promote World Peace... Use your turn signals!
Happyatrest is offline   Reply With Quote
Old 09-15-2019, 03:35 PM   #4
I didn't think we had operational tank heaters. Can somebody verify that?
2018 DX3 37TS Sunset
2019 Rubicon JLU
2018 RZR XP 1000 Ride Command
rskeans is offline   Reply With Quote
Old 09-15-2019, 04:16 PM   #5
Well, I have an operational tank heater switch. Does that count?
2018 DX3 36FK
2013 Jeep JKU
Old 09-15-2019, 08:03 PM   #6
RV Randy's Avatar
If I remember, probably why Rskeans asked the question, Bclemens said we have tank heater switches installed. They light up because they have power but there are no actual tank heaters installed.
RV Randy is offline   Reply With Quote
Old 09-15-2019, 08:13 PM   #7
Forget the hose. Run a space heater in the basement and in the camper if not paying for electirc
Kimber45 is offline   Reply With Quote
Old 09-16-2019, 06:08 AM   #8
“20's night time, 60's day time, what to do?”
What to do???? Enjoy it!!!!!!
It’s still a thousand degrees with 100% humidity down here.
2018 DX3 37BH
mookieblaylock is offline   Reply With Quote
Old 09-16-2019, 12:03 PM   #9
Originally Posted by mookieblaylock View Post
ď20's night time, 60's day time, what to do?Ē
Itís still a thousand degrees with 100% humidity down here.
'Down here' must be Southwest Florida where we are. Heat indexes around 105 today.
David and Vicki
8 year old Springer rescue Sydney
2018 Silverado LTZ 3500HD Dually Crew Cab Duramax/Allison stock "Polar Bear"
2019 Grand Design Reflection 337RLS "The Dog House II"
Andersen Ultimate 5th wheel hitch
EezTire TPMS
Springerdad is offline   Reply With Quote
Old 09-16-2019, 12:15 PM   #10
Hot as blazes here in Texas.
When we camp with temps below freezing, we disconnect from the campsite water hose, turn off the water pump at night, open the cabinet doors near the pipes to warm the space and open the water faucets. Probably overkill, but opening the water faucets allows the water to expand and not burst a plastic pipe.
Wish we were reverse snowbirding and joining you to enjoy the cooler weather.
Happy Camping!
2015 Dynamax REV 24TB class C
2nd rig 2006 Toyota Tundra &
2010 Cikira 21RB 19' travel trailer
Reverse_snowbird is offline   Reply With Quote
Old 09-16-2019, 01:47 PM   #11
JWood422's Avatar
Iím surprised to hear that opening faucets helps much if any. I had an exterior trap with no pressure burst. That water had lots of room to expand. It chose to expand toward the pipe walls.
JWood422 is offline   Reply With Quote
Old 09-16-2019, 03:19 PM   #12
Grapehound's Avatar
[I know I read about this on the forum but can't find the thread. We are going to Mammoth Lakes this coming weekend. Weather app says it will be 25 degrees at night, 60's in the day. Anything special we need to do to prevent anything bad happening to the pipes/plumbing at night? Is overnight cold long enough to worry about it? Should we simply fill the tank and not hook up to the water at the campsite? Any suggestions welcome!]
(I5 30 FW 2018)
It's very likely you don't have to do much of anything at those modest temps.
I'd probably ditch the hose and fill your water tank, or at least disconnect and drain the hose at night. If you have tank heaters and wish to be cautious, turn them on overnight. If you have a basement, then a little heater in there on "low" overnight is an extra precaution, though likely not necessary at all. (Only if campground is supplying electric.) Just make sure it is positioned away from anything flammable.
If you keep your interior 60 or better at night you likely don't have to worry much about internal plumbing either. Open cabinet doors as others have said if you let the inside get cold overnight.
As most have said, you're probably in good shape if you do nothing. However it's always good to know what you would do if really cold temps persisted overnight.
2014 Rockwood Signature 8282 Ultra-Lite
2008 RAM 3500 HD DRW Laramie Megacab
6.7 Cummins Turbo Diesel
Grapehound is offline   Reply With Quote
