Old 08-10-2017, 07:56 AM   #1
Whalenss's Avatar
A/C in Isata 5 question.
Plugged into 50 amp shore power using front and rear a/c. Temp set the same on both thermostats.
When set temp is reached the rear unit turns off but the front unit continues to run in fan mode. It doesn't turn off.
Have searched the Dometic web site but cannot find a trouble shooting guide.
Is this normal or is there a problem with the thermostat or a/c unit.
Thanks.
Pat
2017 Isata 5
Whalenss is offline   Reply With Quote
Old 08-10-2017, 04:59 PM   #2
It sounds like you have the front thermostat set to run the fan in manual mode instead of auto - cycle the thermostat to off, then hit the power button once more, and you should be on the fan setting - hit the up/down buttons until it reads auto, then cycle to your A/C setting, and it should start behaving again.
2017 Dynamax Isata 5 35DB
random_james is offline   Reply With Quote
Old 08-10-2017, 05:52 PM   #3
Whalenss's Avatar
Yes, that was the problem. Rear fan set on auto and front on hi.
Thanks!
Pat
2017 Isata 5
Old 08-10-2017, 10:28 PM   #4
Glad it was a simple and quick fix - those are the best kind!
Old 08-11-2017, 03:20 PM   #5
Dometic JUNK...
I have had lots of problems with Dometic AC"S they are JUNK....
Save a beer for me!!! Happy Trails....Be Safe....
sunnyinfla is offline   Reply With Quote
Old 08-15-2017, 07:52 AM   #6
This past weekend, our front unit started pissing water all over the floor. Have any of you seen this before? I just shut it off as it wasn't that hot out. I attributed it to a clogged drain, but am curious if any of you all have had the same issue?
Mike "Junior" Johnson
2018 Isata 5 36DS
Juniorj is offline   Reply With Quote
Old 08-15-2017, 07:59 AM   #7
Kenny kustom's Avatar
Yup! [emoji1360]
2017 Dynamax Isata 4
Old 08-15-2017, 08:05 AM   #8
Originally Posted by Kenny kustom View Post
Yup! [emoji1360]
Was your issue a clogged drain Kenny?
2018 Isata 5 36DS
Old 08-15-2017, 11:51 AM   #9
I’m not sure!
I’m going to have to get up there and look.
That can wait till I get home.
Old 08-15-2017, 12:52 PM   #10
Commercial Member
Found it. These were all supposed to have been taken care of, but I wonder if they had some old stock laying around or, just missed some. Anyway...sounds too familiar, so worth a look.
File Type: pdf TSB for Condensation 19539_A34-6A--D1.pdf (259.2 KB, 37 views)
If "Search this Forum" does not yield answers, please post questions as a "New Thread" (instead of asking privately) so others can benefit from the answers.
Subscribe for "How To" videos and updates https://www.youtube.com/c/DynamaxRVs/
Sales-Service-Parts https://dynamaxcorp.com/contact-us
bclemens is online now   Reply With Quote
