02-19-2019, 10:23 PM
Add shelf to large kitchen cabinet over sink
We have a new 2018 Isata 4 25FW and am looking at options to help us utilize the large kitchen cabinet over the sink. Attached is a picture of our kitchen from the dealership photos. Has anyone done anything creative to put in shelving or other techniques to better utilize this big space?
I'm hoping to put in shelving but am worried about mounting into the thin RV wood sides of the cabinet.
Thanks for your help.
02-19-2019, 10:46 PM
When I added a shelf in mine (different camper, but same idea) I just glued and screwed a 3/4" X 3/4" wood strip on each end of the cabinet to support the shelf I think I used 3 screws for each support. The wood is thin, but my wood strips can hold a lot of weight since the force is all directly downward and is more shearing force rather than pull out force.
Ray
2017 Rockwood 2109S
Ram 1500
Me Her And a furry little dog
US Navy Veteran
02-20-2019, 08:01 AM
I added a shelf in our Force. used thin adjustable shelf brackets with thin screws. They have little clips that can be moved easily.
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
2023 Dynaquest XL 3700BD
Had...2018 Force HD, 2016 Force, 2014 Thor 33sw
02-20-2019, 09:28 AM
Commercial Member
At home, I just use a wire shelf...so if I ever decide to repurposed for taller stuff I have it.
They make a wire shelf for kids lockers...it has legs, so you just slide it into place, double the space. Then it's removable.
https://www.amazon.com/d/Utility-Rac...rds=wire+shelf
02-20-2019, 09:37 AM
I put an additional shelf in our Grey Wolf. I didn't want to use screws because shower is on one side and frig on other side with thin wall between. I glued 1/2x1/2 (?) supports in each corner, then glued same size strips front to back laying on corner supports to hold shelf. Not particularly pretty (I need to stain it dark), but it works.
Mitch in MN
2018 Patriot (Grey Wolf) 23MK travel trailer
2011 Durango 5.7L and OEM tow package
02-20-2019, 09:40 AM
I used adjustable shelf brackets and cut to fit.
Pat
2017 Isata 5
02-20-2019, 10:02 AM
Originally Posted by Whalenss
To keep the shelf from sliding, used command strips cut to fit on the 4 shelf hangers.
Pat
2017 Isata 5
02-20-2019, 10:13 AM
Command strips, that's a great idea, probably keeps the shelves from vibrating also.
Phil and Jan
2018 Isata 5 36DS 4x4
2021 Jeep JL Rubicon
02-20-2019, 02:16 PM
Buy/cut some wood (e.g., 1x8, 1x12) to match the depth of the cabinet. Make an upside-down U of three pieces. Slide it in. Remove/replace door hinges if necessary.
Larry
02-20-2019, 04:53 PM
I use a set of these shelves for my over the sink cabinet on one side and a upright divider for dishes and lid covers. You can also get ones that hook together to make another level.
https://www.amazon.com/mDesign-Adjus...garden&sr=1-33
Rita B
2016 Surveyor 201RBD
2006 Jeep Commander 5.7 Hemi
Camping
2017- 27 days,2018- 100 days, 2019- 35 days
02-20-2019, 07:07 PM
I use adjustable wire shelves, no drilling etc, and can be removed or moved. Any way you do it adds storage!!
Kevin & Jean
2018 DX3 37BH
02-20-2019, 08:22 PM
+1 that is what we did worked great
02-20-2019, 08:24 PM
We had a cabinet in our previous minilite, like a broom closet. Used the adjustable shelf brackets to add three shelves. Didn't want to chance puncturing anything behind the wall. Drilled carefully to just get through the wall and used pop rivets to fasten the brackets. Not much for a screw to bite into.
02-23-2019, 05:51 PM
Couple of Ideas
Put this in the top pantry space on our 31DS. https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1 Makes a lot of room for wine and uses the dead space.
Then we had the dead space behind the TV in the living area. This was a large hole and this worked nicely. https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1 Works out great for chips, cereal and many bulky items.
Both these really help utilize the space provided.
Bill & Sue
Southwest Missouri, retired
2018 Dynamax Series 4
2014 Explorer & 2006 Jeep Unlimited
