Old 12-08-2018, 12:54 AM   #1
Air suspension hopefully fixed...
So, the dealer has had my DX3 for at least 3 times to fix the air suspension. Each time I get it back, it leaks down sooner and sooner. Before I took it to them, it took about a week to leak down, then a couple of days and now less than an hour.
I was suppose to take it back but figured I'd crawl under the suspension and check it out myself.
I found two of the schrader valves were leaking air. I was going take it apart but instead, I pushed the valve in, blew air in it and tried to clean it.
I don't know if that fixes the problem but my suspension has stayed air'd up for 3 days so far and I don't hear any air leaking...
Hopefully that fixes it.
Mark
Orangecrush is offline   Reply With Quote
Old 12-08-2018, 10:07 AM   #2
Mark, you may already use them but I found some filtered valve cores that I have used on tire valve stems and brake system air tanks where there may be particles preventing the schrader valves from sealing.
https://www.amazon.com/Z-Tire-Beads-...a-568857246602
Phil and Jan
2018 Isata 5 36DS 4x4
2017 Jeep Cherokee Tralhawk
I5PhilGa is offline   Reply With Quote
suspension
