Old 10-05-2016, 12:12 PM   #1
halla's Avatar
Alcoa Rims
Well this may seem like a stupid question, but I am allowed to ask at least one stupid question per day.
On our Freightliner M2's, does anyone know if the Alcoa rims that come on them are coated or not? The wheels feel like they are clear coated, but I cannot tell.
As you guys know, you can only use certain cleaners/polishers on coated wheels.
I have some nasty water spots that are not cleaning off and I want to buff them out, but I dont want to hurt the clear coat if they are coated.
Alcoa didnt seem to know, I wasted about 3 hours on the phone trying to find out.
halla is offline   Reply With Quote
Old 10-05-2016, 12:37 PM   #2
Iwannacamp's Avatar
See if this fixes it.....If it does... fax me a beer!
http://www.alcoa.com/alcoawheels/cat...EVO_Wheels.pdf
2017 Puma 297RLSS
2005 Ram 2500 4X4 diesel
Our new 5er 10-26-16
Old 10-05-2016, 12:38 PM   #3
Decon Blue's Avatar
Some are, some are not. I used to work at truck stop garage. You could tell when you did tire changes. Easy way to tell is get some Semi Chrome or Mothers alum polish and if they are clear coated your rag will not turn black.
Retired and loving it. Still looking for that perfect high.
Decon Blue is offline   Reply With Quote
Old 10-05-2016, 12:39 PM   #4
halla's Avatar
looking at that brochure, mine does not have the dura bright sticker, so I am guessing that means that are uncoated.
Old 10-05-2016, 12:41 PM   #5
Iwannacamp's Avatar
another one...
http://www.alcoa.com/alcoawheels/cat...al_english.pdf
p 21-22 i think
2017 Puma 297RLSS
Old 10-05-2016, 04:54 PM   #6
AWF1945's Avatar
Mine are not coated. I do use mothers to polish them up. Sometimes during my travels I run across guys doing it in the parking lot of truck stops $ 10.00 a wheel. I jump on that.
Slim, RVing 30 plus years
2015 Dynamax DX3 37 RB
AWF1945 is offline   Reply With Quote
Old 10-05-2016, 07:04 PM   #7
halla's Avatar
Great. Thank you for all the prompt replies. I now know how to attack this issue.
2016 Dynamax Force. Just-Rite2
2018 Dynamax Force HD BH---Just Rite-2
Old 10-05-2016, 07:38 PM   #8
Myself, I don't like coated wheels because at some point, from a stone chip, moisture will get under the clear coat and cause the aluminum to white rust...and it starts looking worse and worse.
My rims were clear coated and I used Zinzer stripper and a pressure washer to strip and then polished them.
Never use clamp on wheel weights either, Just adhesive ones. The clamp on weights will compromise the coating and the wheels will oxidize around the weight.
SidecarFlip is offline   Reply With Quote
Old 10-06-2016, 07:14 AM   #9
Years ago I had a Corvette with Fikse racing wheels. Center part of the wheel was clear coated and outside was polished aluminum. Fikse recommended using Simple Green cut in half. Spray on when wheels are cold. Wash rest of car and wheels last.
Worked Great. Still use it on all my vehicles. Hope this helps.
_______________
MK Clark
2819VS Windjammer
MKClark is offline   Reply With Quote
Old 10-08-2016, 09:34 PM   #10
Our M2 Alcoa wheels have a part number stamped. Then the Alcoa web site has info on the wheels and cleaning recommendations.
dmax36 is offline   Reply With Quote
