Old 07-07-2017, 11:19 AM   #1
Anderson Water Valve Isata 3
I went to fill up my fresh tank and found the place to screw in the hose looks like this. Click image for larger version
ID:	143886 SEE THE BLACK HOLE!!!
Shouldn't there be some type of connector for the hose? I can see wiring inside of it....
HELP!!!
Kstreet1 is offline   Reply With Quote
Old 07-07-2017, 11:22 AM   #2
chroniekon's Avatar
The water hose connection is on the outside just below the electrical connection. It's marked CITY WATER CONNECTION
chroniekon is offline   Reply With Quote
Old 07-07-2017, 11:57 AM   #3
I was not aware that Dynamax was not using the full Anderson panel. I just found that out!
Old 07-07-2017, 12:28 PM   #4
GM
bclemens's Avatar
Well, we use it, but didn't want that connection INSIDE in case you made a loose connection with your hose and it leaked. There is a method to the madness. Valve still works, we just moved that particular connection to a "less damaging" location.
Please READ the entire thread before posting to keep comments relevant.
Also, please post questions as a "New Thread" (not private message) so that others can benefit from the answers. Use Private Messages for sensitive information only. Owners manuals are available online and via iPhone/Android Apps.https://www.dynamaxcorp.com/OnlineManual.aspx
valve, water
