Old 04-19-2016, 05:12 PM   #11
hammer55's Avatar
I have one, some say they are where the glue bleeds through
Mark & Annie
2014 COACHMEN PURSUIT 27 KB
Modesto, Central California
hammer55 is offline   Reply With Quote
Old 04-20-2016, 07:43 AM   #12
Wolverine 1945's Avatar
Defective Wall Board ???
As many have said,,, the glues they use in manufacturing can turn yellow in time !!!
But I have never seen that happen behind the outside layer ???
Wolverine 1945 is online now   Reply With Quote
Old 04-20-2016, 07:09 PM   #13
Yeah-we will just get it fixed. We've only been FT for a couple months now. I'm sure we will find a few other minor things to get fixed...
Mike
2016 Force HD 36
BLK-9 is offline   Reply With Quote
Old 04-21-2016, 07:46 AM   #14
GM
bclemens's Avatar
If you're going to be up in the Elkhart area we can try and schedule you in here. Otherwise we can find a local dealer. I was just about to post a thread on our customer service lounge that I hope to expand in the coming year.
PLEASE do not send questions via Private Message. Post questions in the forum as a new thread so that other users can benefit from the answers. Use Private Messages for sensitive information only. Our owners manuals are available online and via iPhone/Android Apps. http://www.dynamaxcorp.com/OnlineManual.aspx
Old 04-21-2016, 03:20 PM   #15
Thank's Mr. Clemens - I'm not sure when I can get up to Elkhart, IN. I would prefer you take care of this versus a local dealer. I will send you VIN via private message and then let you know when I am able to get up to your area, and then schedule some availability.
Thanks again.
Mike
2016 Force HD 36
Old 04-21-2016, 04:02 PM   #16
GM
bclemens's Avatar
Just make sure to check roof seals. I'd hate for it to be a leak that goes unchecked. Could just be glue that has yellowed or something that got on the surface and yellowed after a period of time...but better to be safe.
Old 04-27-2016, 12:01 PM   #17
GM
bclemens's Avatar
Well, BLK-9. I happened to walk a unit and spotted the same yellow spots (not as bad). It was the first time I found a defect, I was happy about. It meant that it wasn't water damage.
What we think happened was a cleaning agent got on there and was not rinsed off. (its not until you read the bottle that it says it should be rinsed with water). Who knew. We ended up using a different cleaner to clean off the residue of the first cleaner.
Maybe try a spot and see if that yellow wipes off the surface.
Old 05-06-2016, 03:27 PM   #18
Thanks Brian. Any specific brand/type of cleaning agent do I use here?
Mike
2016 Force HD 36
