Old 06-25-2017, 09:05 AM   #1
AquaHot 400D burner will not fire
It has worked perfectly for four months. Electric part is working. Diesel part is not
Symptom. Unit goes thru purge cycle, blower running, after a minute or so burner fails to light and shuts down. Burner light in coach goes off.
1. Fuel tank full
2. Expansion tank full
3. Both high limit thermostats closed
4 No faults on the control panel, all green lights lit and appear normal
5 Found no loose wiring on the control panel, or at the burner control box or any where in there
Does any one have any thoughts?
BClemens. Any thoughts out there?
joet19711 is offline   Reply With Quote
Old 06-25-2017, 12:46 PM   #2
After pushing on every wire sta kon in and around the burner and all the other places inside, burner has decided to ignite and work. It has worked thru three cycles so far.
I Wii keep everyone posted
Old 06-25-2017, 04:26 PM   #3
letsgorving's Avatar
Send a message via AIM to letsgorving Send a message via MSN to letsgorving Send a message via Yahoo to letsgorving
Nice work!
Kevin & Jean
2018 DX3 37BH
letsgorving is offline   Reply With Quote
Old 06-26-2017, 07:22 AM   #4
Commercial Member
That's exactly how it works at home. My wife has a computer problem. Tries all the things I tell her to do normally, finally gives up, calls me in. I walk in the room, she tries it again to show me how its not working and then it works.
You're welcome
If "Search this Forum" does not yield answers, please post questions as a "New Thread" (instead of asking privately) so others can benefit from the answers.
Subscribe for "How To" videos and updates https://www.youtube.com/c/DynamaxRVs/
Sales-Service-Parts https://dynamaxcorp.com/contact-us
Old 06-26-2017, 04:53 PM   #5
You're welcome
I call those kinda things " Gremlins "
did think that one of the sta kons was loose on one the tabs on the hi temp thermostats. All that really matters is that it is " working good " NOW!!!
Joe & Debbie
2017 Dynamax DX3 37BH
Toad: 2020 Ford F-150
burner
