Old 10-06-2017, 09:55 PM   #21
judy3972's Avatar
Send a message via MSN to judy3972
There was a work around ( at least on our DX3).
The light green wire needed to be grounded. There is a thread on here somewhere. Good Luck
Life's a journey, enjoy the trip.
Phoenix, Az.
judy3972 is offline   Reply With Quote
Old 10-06-2017, 10:29 PM   #22
Mine has a camera mounted over the rear view mirror with a rear and side cameras, works great. Here are a few options.
Digital Wireless Backup Camera System Kit, IP69K Waterproof Wireless Rear View Camera + 7íí LCD Wireless Reversing Monitor for Trailer, RV, Bus, Trucks, Horse-trailer, School Bus, Farm Machine,etc https://www.amazon.com/dp/B071WW8Q8M..._IIe2zbHT5FY8B
Or the lock-pick that will allow you to turn the Ram camera on all the time. It notes it's not compatible with the dual camera system but the 5500 only comes with a single camera.
https://www.coastaletech.com/uconnectairv2.htm
vrunner is offline   Reply With Quote
Old 10-07-2017, 03:33 PM   #23
IsataMatata's Avatar
Originally Posted by bclemens View Post
Nope. Other than a whole new camera and monitor. The camera that is back there is a stock Dodge Ram 5500 backup camera. Runs the wiring through the Dodge harness. I see no way to tie into that without CANbuc communication. That's why we went to a completely independent solution.
How do I know which camera system I have? I have a 2018 I5 on a 2017 5500. Right now backup camera works when backing only, but dealer thinks thereís a wiring correction.
IsataMatata is offline   Reply With Quote
Old 10-07-2017, 04:02 PM   #24
Tiltin Hilton
Does your camera/monitor only come on in reverse? If so there is a extra wire from the Monitor that ties into Back up light circuit near monitor. When in reverse, the camera may be powered in rear or the monitor may get power from this circuit under the dash. Remove that wire from that circuit and connect to power on wire from camera or Ignition on hot circuit. That would keep "on all the time" situation. Without more info, I'm suggesting without checking out in detail PM for details
drmoparPHD is offline   Reply With Quote
Old 10-07-2017, 05:25 PM   #25
GM
bclemens's Avatar
If you have side cameras on an Isata 5, then you have the new back up camera. For those posting about changing the reverse wire, that is on everything BUT the Ram 5500. Ram 5500 is the only unit that we run the stock stereo (8.4" uConnect) They do not offer a radio delete because so many things are controlled via the CANbus which is tied unit that radio. The reverse signal is not an analog power wire, but is just a signal through the CANbus. So we had to have a module developed that would read the left/right/reverse signals and convert that to a normal 12v signal to activate normal 12v side and reverse cameras. The only way to get "all time" back up view on the early Ram 5500 is through a software command that Ram tells me is not available on the Cab chassis. Or, use a wired/wireless monitor/camera system that just comes on when you push the power button.
Please READ the entire thread before posting to keep comments relevant.
Also, please post questions as a "New Thread" (not private message) so that others can benefit from the answers. Use Private Messages for sensitive information only. Owners manuals are available online and via iPhone/Android Apps.https://www.dynamaxcorp.com/OnlineManual.aspx
Old 10-09-2017, 09:28 AM   #26
Brian I have a 2018 with the side view cameras on my unit but canít figure out how to get the rear view monitor to come on when in drive. was this fixed on the 2018?
ctboatman is offline   Reply With Quote
Old 10-09-2017, 10:26 AM   #27
Kenny kustom's Avatar
A few points.
You cannot replace the radio in a ram with the 8.4 screen.
Custromix from Europe has a jailbreak software update that allows video to be on at any time.
I had it on my 2500. I could switch between rear cam and front cam at will.
It also turns on front cam when under 10kph in drive. Really handy.
2017 Dynamax Isata 4
Old 10-09-2017, 10:29 AM   #28
Kenny. I have tried contacting them but they told me that I would need some electrical engineering abilities to change the canbus woring
Ctoth11 is offline   Reply With Quote
Old 10-09-2017, 11:18 AM   #29
GM
bclemens's Avatar
I just walked out to one. Fired up the engine. Hit the power button the monitor (this is clipped over the existing Dodge rear view mirror) and the rear camera popped right up.
Can you post a picture of what you are looking at so we're all on the same page?
Old 10-09-2017, 03:33 PM   #30
Attached picture is monitor hooked to my 2018 I5. When I push the button nothing happens, backup works in reverse and side cameras when work when turning. Dealer thinks itís a wiring harness issue. But we have not confirmed service appointment yet.
back up camera
