Old 10-25-2017, 09:11 AM   #41
Originally Posted by bclemens View Post
If it is working in reverse and with side cameras, it has power. So hitting the power button while in drive or park and changing the AV source should do it. If not, then it could be a loose AV connection, thus the yellow wires in the A pillar as shown in the picture.
That's what I was thinking... it's getting power from the reverse/turning triggers, but something is wrong with the constant power....
RV_Fan44 is offline   Reply With Quote
Old 11-25-2017, 03:18 PM   #42
MouseHouse's Avatar
Our service appointment is next month so hopefully we'll get camera issue resolved, but discovered today that the camera comes on when the hazards are turned on.
2018 Dynamax Isata 5 36DS
MouseHouse is offline   Reply With Quote
Old 12-17-2017, 10:45 AM   #43
MouseHouse's Avatar
Just to follow-up, our I5 is currently being serviced. Dealer said a wiring issue caused the rear camera not to work in drive and dealer says it has been corrected.
Old 03-18-2018, 04:01 PM   #44
Ok everyone I figured it out. The dealer hooked up the wires incorrectly to the monitor. The bottom line is that the monitor has a blue output that hooks up to a purple reverse wire and a red wire thatís supposed to hook up to the constant 12v. These two wires were switched. They are located directly behind the emergency brake release and are very easy to switch.
ctboatman is offline   Reply With Quote
back up camera
