Old 08-07-2016, 01:11 PM   #11
Can all owners please tell me if your a/c shuts off with thermostat temp...my compressors cycle by temp but fans stays on all the time
fred555 is offline   Reply With Quote
Old 08-07-2016, 02:14 PM   #12
Rrzasa's Avatar
Yes, mine do but when I first got the coach, the fan on the air unit was set to low instead of auto so even after the temp was reached, the fan kept running. Just go to the fan setting and select auto.
Rob & Rosanne Rzasa
2017 Dynamax Isata 5 36DS
Go Gators
Rrzasa is offline   Reply With Quote
Old 08-07-2016, 02:23 PM   #13
I have fans set to auto and they still run all of the time
Old 08-07-2016, 02:50 PM   #14
FOURWHL's Avatar
My fan stays on when on auto as well. I kind of like it though. Less noticeable when the compressor kicks on
2016 Dynamax DX3 - Big Blue
FOURWHL is offline   Reply With Quote
Old 08-07-2016, 03:23 PM   #15
Hello your a new owner? There are a few of us who got the intial Isata 5
Old 08-07-2016, 03:27 PM   #16
FOURWHL's Avatar
I've had my DX3 since Easter. Not sure if the different model makes a difference or not.
Old 08-08-2016, 08:49 AM   #17
GM
bclemens's Avatar
According to Dometic/Atwood...
If it is an Atwood and it is on “auto” the fan will run all the time and the compressor will kick in/out when necessary. If it is a Coleman or a Dometic, the fans should shut off on “auto”.
PLEASE do not send questions via Private Message. Post questions in the forum as a new thread so that other users can benefit from the answers. Use Private Messages for sensitive information only (VIN, Contact info or things you do not want the public to see).
Old 08-15-2016, 07:19 AM   #18
Lucky me I have the Atwoods
Old 08-15-2016, 07:20 AM   #19
I am sure the fan will have shorter life though
Old 08-15-2016, 07:26 AM   #20
I would be VERY interested in knowing why they decided to change something that has been standard in the industry for such a long time?
Why even have an 'Auto'?
2016 Flagstaff 8529IKBS Diamond Package 5th Wheel
Ford F-Series SCREW 4x4
TST Tire Monitor - Sinemate 3500w Gen.
Nights Camped: '15 = 22'16 = 46
bed, roo
