07-10-2018, 05:55 PM
Bedroom slide won't go out!
I'm in our 2018 Force 36FK cleaning today and the living and kitchen slide are working but the bedroom is not. Hubby checked the fuse and said it looked like one fuse fed all three. I am plugged into shore power at my home. Anybody got any ideas???
Ron & DeLana
2018 Force 36FK
2003 Newmar
1998 Pursuit
07-10-2018, 08:09 PM
Make sure that the ignition key is off. Our is locked out if the engine is running.
2018 DX3 37TS Sunset
2019 Rubicon JLU
2022 RZR Pro 4 Ultimate
07-10-2018, 11:58 PM
Also check to see that brake is fully engaged. Had occasion a few years ago trying to break camp , could not get bedroom slide to come in. . I released and reset brake couple times and found it was not engaging , setting completely. Apparently has a lockout sensor of some kind. Needed to do a little adjusting
turning of brake pull knob. Also realized Key had to be in Accessory position /Left not Start right. Worth a try. SS
07-11-2018, 08:16 AM
Commercial Member
Yes, the trucks are one that have two different slides. Norco (Cables slide in the bedroom) and Power Gear (Below floor electric ram in the front area). I think at one time, you needed key on for the front, key off for the back or something like that. I asked the EE and he said that's what the install called for. I explained that we should wire them the same and let the slide supplier change their info to an either/or. Or find a new slide supplier.
07-11-2018, 08:21 AM
Thanks for the reply. The key wasn't in the ignition but we are going to go ahead and start the RV and then turn off and make sure it is in the off position.
Ron & DeLana
2018 Force 36FK
2003 Newmar
1998 Pursuit
07-11-2018, 08:36 AM
I have tried the ignition key with no success. With the bed in I don't see how I can access the motor or controls. It looks like there is only one fuse feeding all three slides, and the other two work fine. Is there a trouble shooting guide that I can get? Thanks for your help, Ron
Ron & DeLana
2018 Force 36FK
2003 Newmar
1998 Pursuit
07-11-2018, 08:44 AM
Commercial Member
Brake engaged I assume? Not getting any codes? I would try engine off, key out, brake engaged.
07-11-2018, 10:00 AM
Yes, engine off, key out, brake engaged. No joy.
The slide is not doing anything, no noise, no clicks, no nothing. I'm assuming there is no power to the motor or that a limit switch or potentiometer has it off.
Is the toggle switch for the slide what reverses the motor? I will probably pull it next to see if I am getting power in and out. Other than that, I am afraid I may have to disassemble something to get to the motor and controls.
Thanks, Ron
Ron & DeLana
2018 Force 36FK
2003 Newmar
1998 Pursuit
07-11-2018, 10:21 AM
You can take out the panel under the bed to access the motor and cables.
DYNAMAX 2016 FORCE HD
07-11-2018, 10:24 AM
Forgot I had images.
07-11-2018, 02:00 PM
Check fluids
Be sure to check Hydraulic fluids, as you use slide outs the level is reduced, naturally, they never supply an abundance of fluids on these new models.
07-11-2018, 02:05 PM
Commercial Member
I hope the hydraulic fluid for that rear slide is found to be empty...cause its an electric cable slide.
07-11-2018, 03:34 PM
Dang Brian I just blew water all over my laptop screen.
Formerly Mountieman
07-11-2018, 08:18 PM
Lol, make sure you double ck your blinker fluid while you're at it. [emoji41]
Slim
Slim, RVing 30 plus years
2015 Dynamax DX3 37 RB
07-11-2018, 09:43 PM
I have no motorhome. .. have you tried the remote and the switch... assuming you have both? Causes odd things to happen. Is there a thermal reset on the motor? Cheap checks
2017 Puma 297RLSS
07-12-2018, 10:02 PM
There is power to the toggle switch which controls the slide and there are only three wires on the switch so I am assuming there is a controller located somewhere. Does anyone know where it is on our Dynamax 36 FK? I cannot find one for the bedroom slide.
It looks like we will have to remove part of the bed support to get access to the motor and drive unit and thought the controller may be located in the same location.
Thanks for all the help, Ron
Ron & DeLana
2018 Force 36FK
2003 Newmar
1998 Pursuit
07-12-2018, 10:12 PM
Is that the side of the bed that you removed to get access to the drive and motor? Ron
Ron & DeLana
2018 Force 36FK
2003 Newmar
1998 Pursuit
07-14-2018, 12:57 PM
Bump.. fixed?
07-14-2018, 01:04 PM
Our DX3 37BH 2018 is key "on" for rear bedroom slide
Kevin & Jean
2018 DX3 37BH
