Old 04-16-2019, 08:07 PM   #1
jtad's Avatar
Bedroom TV mount 37BH
The previous owners of our 2016 37 BH DX3 took the bedroom TV and all the mounting hardware. I could rig something up but was wondering was they used from the factory. All of the 32" TV's I've looked at and measured are going to be a tight fit in that cubby. Maybe Brian can chime in and let me know what they use and if it is avail for purchase.. Thanks
2016 Dynamax DX3 37BH
2015 Jeep JKU
jtad is offline   Reply With Quote
Old 04-17-2019, 08:55 AM   #2
Commercial Member
we have used several over the years. Nothing special. Most we use now, just mount to a door and then the other side mounts to the TV. Uses a keyhole slot.
We have also drilled through the door and mounted right to the door itself.
If "Search this Forum" does not yield answers, please post questions as a "New Thread" (instead of asking privately) so others can benefit from the answers.
Subscribe for "How To" videos and updates https://www.youtube.com/c/DynamaxRVs/
Sales-Service-Parts https://dynamaxcorp.com/contact-us
Old 04-17-2019, 12:46 PM   #3
I have a Force 37BH. If I were in your situation and had to remount or install a new TV, I would find a bracket that allows the TV to be "flipped up" so as to access the large amount of storage that is essentially lost with the factory install. Would be a great place to mount a small safe!! I have considered changing it, but of course "the enemy of good is better!!" Please let me know if you find such a bracket in your search.
randocommando is offline   Reply With Quote
Old 04-17-2019, 04:15 PM   #4
jtad's Avatar
Our Seneca had a mount in the bedroom that you pulled a rope and it released the tv to swing out of the way and you had access to that area. I cant seem to find a mount like that anywhere.
2015 Jeep JKU
Old 04-18-2019, 03:48 PM   #5
The Newsoms's Avatar
I haven’t looked recently but Morryde had several different types of mounts.
Jimmy & Teresa Newsom
2018 Riverstone 38RE/2019 Sundowner Toyhauler
2020 RAM 3500 SRW
The Newsoms is offline   Reply With Quote
Old 04-18-2019, 04:25 PM   #6
You may want to look at Ramco Engineering:
https://shop.ramco-eng.com/collections/moview-mounts
Rick & Kem
2019 RAM 2500 6.7 Cummins Diesel
2017 Rockwood 2606WS
rac54 is offline   Reply With Quote
Old 04-18-2019, 06:23 PM   #7
I just bought their MSCSL12-QD × 1 to mount a bedroom TV. It is a smaller version the same mount as what was used in the living area.
They turned the order around quickly and it came with all of the hardware.
Bob
https://shop.ramco-eng.com/collectio...-mounts?page=2
HappyTrav is offline   Reply With Quote
Old 04-18-2019, 07:14 PM   #8
Blog: RVroadtripper.com
hbillsmith's Avatar
TV Mount to Fold Up
Something like this might work for you. I've found this vendor to have the broadest selections and the best prices.
Click Here for: Mount-It! Under Cabinet Folding TV Mount
It says up to 27" but with today's light weight LED TV's you could just shop for the size TV that best covers the front of the cabinet. With a 44lb. weight limit on the bracket you could easily do 32" and possibly even 40". Just make sure the TV you select has either a VESA pattern of 75x75 or 100x100 ; it will say so either on the box or you can look at the TV online to get the VESA pattern. Just about any TV under 32" has VESA 100 support.
Maxxis 235/80/16E; AirBags w/AirLift1; mor/Ryde Rubber Pinbox; Andersen UltimateII Alum. 5erhitch on Reese Flipball w/Curt 4" offset; LCI Ground Control3; King Dishtailgater; Traveling with 10' Portabote;
hbillsmith is offline   Reply With Quote
bed, mount, roo, tv mount
