Originally Posted by halla
This Koa in Virginia, there is a gas class a with the front wheels about 3’ off the ground. The front jacks are in shaky boards, we are half expecting their jacks to buckle. It looks as if the brackets arent very sturdy in crappy conditions. Please keep us in the loop with your repair.
I had to recalibrate the "zero point" on my Lippert Power Gear levelers because the Auto function from the factory thought the rear was too low even when manually leveled. I use a ball as a double check on the phone's Bubble Level app and it would not roll in any direction.
The recalibration procedure says to manually lower the jacks on a level surface until they just touch and then raise the coach about 3".
That told me, rightly or wrongly, that the jack's should not be carrying a lot of the load so I bought twelve of the Quality Plastic pads and now try to get it level before dropping the jacks. I just put them under the tires, not under my SnapPads.
Obviously I have no idea what happened here but I have stopped letting the Jack's extend very far, which I used to do.
Humm, in re-reading what I wrote I'm now wondering if I should in fact put an equal number of Quality Plastics pads under the jack's to keep their overall extension to a minimum. I don't think they would slip but maybe they would in mud.
FWIW,
Ray
