Old 02-19-2016, 09:32 PM   #11
After a second thought, our Black flush is a separate input requiring a hose connection. This would be a entirely separate water system not in any way connected to the M.H.. I am curious if "Code" would sill require a Back Flow Preventor.
dmax36 is offline   Reply With Quote
Old 02-19-2016, 09:55 PM   #12
Members
Tommy Joann's Avatar
The back flow preventer is required to keep from fouling the campground water supply!
2015 Flagstaff 8528CKWSA Diamond Package
2015 Chevy Silverado Crew Cab LT
Husky 16K W Hitch w/ Husky 10-16 Composite Glider
Reese Revolution Pin Box
Tommy Joann is offline   Reply With Quote
Old 02-19-2016, 10:10 PM   #13
AWF1945's Avatar
Its a simple system. See bubbles previous post with the picture. Yes, it's a separate line... mine is just not working should be a simple fix.
Slim, RVing 30 plus years
2015 Dynamax DX3 37 RB
AWF1945 is offline   Reply With Quote
Old 02-20-2016, 08:23 AM   #14
GM
bclemens's Avatar
Arrowd on the check valve are hard to read, but this it too common an issue. I had this at Sunseeker as well. I'll go check some online spot check direction. Then the valve itself. Maybe we're all just buying the same valve.
PLEASE do not send questions via Private Message. Post questions in the forum as a new thread so that other users can benefit from the answers. Use Private Messages for sensitive information only (VIN, Contact info or things you do not want the public to see).
Old 02-20-2016, 09:57 AM   #15
bubbles's Avatar
This is what my Georgetown MH uses. As can be seen the input is from the bottom through the shut off disk controlled by pressure from outside connection and the top vacuum opening (vented to ambient) allowing input and closure of the disk when pressure is applied/removed. The output side connection (to black tank) is spring loaded to the closed position (toward main valve cavity) and opens when pressure is applied. I know this is not identical to the one in this issue but I believe the internal functioning is the same. Where this item is situated in the unit above floor level; for me 5 feet, well above the black tank, contamination of any sort is a moot issue.
Old 02-20-2016, 12:15 PM   #16
AWF1945's Avatar
Thanks for all the help gang. Problem identified. .. lines are reversed.
Old 02-21-2016, 01:06 PM   #17
Curosity got the best of me and I checked. Yep, ours is backwards also. For Brian's info, I don't know if the fitting installer is the same guy who run the lines, but the lines were crossed in the bay.
Can the fitting be simply rotated leaving the vent horozontal rather than on top ?
Old 02-21-2016, 02:48 PM   #18
I wouldn't. I don't think it will work sideways.
2012 Roo19 - hybid (2012-2015)
2011 Traverse LT, 3.6L, FWD
Old 02-21-2016, 04:30 PM   #19
AWF1945's Avatar
It needs to be installed just as shown in picture. It has a ball, or similar that drops down and seals it off. Any other positions won't work.. I already check that possibility out..
Old 02-21-2016, 07:05 PM   #20
AWF1945's Avatar
Resolve, a trip to the local hardware. Sharkbite fittings, reverse the lines.. works like a champ. This way I didn't have to buy crimping tool and all that. Teflon tape of course is a must. Now I need to go to the chiropractor :-/
ID:	100094   Click image for larger version
black, black tank, black tank flush, tank
