Old 02-21-2016, 07:07 PM   #21
fonzie's Avatar
Originally Posted by AWF1945 View Post
Resolve, a trip to the local hardware. Sharkbite fittings, reverse the lines.. works like a champ. This way I didn't have to buy crimping tool and all that. Teflon tape of course is a must. Now I need to go to the chiropractor :-/
Fonzie
Nights Camped: 2011(21) 2012(36) 2013 (17) 2014 (18) 2015 (18) 2016 (36)
Old 02-24-2016, 12:56 PM   #22
Just as a curosity: How can a pressured supply line be contaminated by a non-pressurised vented line ?. I've heard of firetrucks being able to pull water backwards as a reason in homes, but I can't think of any other reason..... Thanks in advanced for the education.
dmax36 is offline   Reply With Quote
Old 02-24-2016, 03:00 PM   #23
Members
Tommy Joann's Avatar
A loss of pressure in the supply can have a siphoning effect on non-checked outlets and draw in fouled water mud, etc. hence boil water after drop or loss in your city or county systems. Code requires all water meters to have a back flow preventer installed.
I am a retired lead maintenance mechanic at a large hospital system in Atlanta. Believe me if those back flow preventers failed annual inspection they can lockout the city water supply for the entire hospital. We had bypasses with bf preventers on every water meter!
2015 Flagstaff 8528CKWSA Diamond Package
2015 Chevy Silverado Crew Cab LT
Husky 16K W Hitch w/ Husky 10-16 Composite Glider
Reese Revolution Pin Box
Tommy Joann is offline   Reply With Quote
Old 05-30-2016, 01:02 PM   #24
mike.t's Avatar
I took the screen out of mine and all I see is a 1/4" hole no valve? Or are you saying the black plastic peace is the only valve?
2015 Salem 27RKSS
2015 Ram 2500 CC 4x4 Cummins
55' Chevy Bel-Air
Burgers on the BBQ and a cold beer
mike.t is offline   Reply With Quote
Old 05-30-2016, 01:08 PM   #25
mike.t's Avatar
Thanks for the quick response. . I did find it.. my guess is, the lines are reversed. Wonder does it have to be on that upward position to work..
Thanks for taking the time and send a picture.
Guess? Connection on the bottom is from water flush hose connection
2015 Salem 27RKSS
55' Chevy Bel-Air
Old 05-31-2016, 12:18 PM   #26
AWF1945's Avatar
If you look back at my pictures you see the valve. Its under the bathroom sink inside the coach. It has an arrow on it showing direction of flow. The line in is the lower pex as shown. It comes from city hookup where I'm guessing that's where you pulled the screen out?? Not sure I understand what your asking..
Slim, RVing 30 plus years
2015 Dynamax DX3 37 RB
AWF1945 is offline   Reply With Quote
Old 05-31-2016, 12:45 PM   #27
mike.t's Avatar
I was asking the location of the 1 way valve. Now I know it is in the piece under the sink. My other question was the opening inside of the black tank flush connection looks awfully small. about a 1/4"
2015 Salem 27RKSS
55' Chevy Bel-Air
Old 05-31-2016, 02:14 PM   #28
AWF1945's Avatar
It works good when installed properly
Old 05-31-2016, 03:06 PM   #29
mike.t's Avatar
2015 Salem 27RKSS
55' Chevy Bel-Air
Old 05-31-2016, 06:30 PM   #30
VinceU's Avatar
Originally Posted by mike.t View Post
I think he meant "piped properly. As to the 1/4" opening in the nozzle' that's really too large. The design through is to cause a large pressure drop from the restriction and thus cause the water to become "jets".
black, black tank, black tank flush, tank
